A few basic causes.
1. The cartridges you bought were not original equipment ones (OEM)and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printer through the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
run the cartridge alignment process
If you are filling them yourself then...
Cartridge ink levels are usually monitored by a small chip on the cartridge. If that cartridge is allowed to fall below 25% ink level most chips then become locked and not able to re-set.
For many cartridges you can buy a reset device to reset chips that have not become locked. Or you could buy empty cartridges that don't need resetting and that will always accept a self refill.
If this information was useful please click below
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
