Question about Toshiba Office Equipment & Supplies
We have a Toshiba EX4T1 printer that is currently showing an error stating “the ribbon motor torque sensor has a problem” Anyone have any idea where the sensor is and how to fix. I replaced the ribbon motors already but still an error occurs when printing with Ribbon.
6ya staff
SOURCE:
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: adler royal satellite 40 ribbon drive problem
Try holding the code key down and pressing the (.) period key. It is probably in the mullti strike ribbon mode.
Posted on Oct 19, 2007
pkwc
  • 254 Answers
SOURCE: RIBBON ERRORS
Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
- The ribbon roll is not correctly fitted to the spindle.
- The sensors detecting the rotation are out of order or completetly filled with dust or grease.
In this case clean the sensors.
Another reason may be due to Direct thermal printing with a ribbon mounted.
Posted on Sep 03, 2009
Raj Pots
  • 16 Answers
SOURCE: Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
Posted on Sep 08, 2009
Anonymous
SOURCE: Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Posted on Nov 16, 2009
Ritesh Shah
  • 43 Answers
SOURCE: datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Posted on Nov 23, 2009
I am having trouble with my Canon imageRUNNER C9070 PRO. i cant copy or print anything, if i want to copy the screen shows me error code "E000008-0001". Anyone know how to stop this from?
Pressure belt unit life detection error
The amount of fixing motor current reached the specified
value due to torque-up of the pressure belt.
1. Confirm the current value is 80 (0.8 A) and below on
the service mode (COPIER> DISPLAY> FIXING> FXMTR8).
A. In case that the current value is "smaller than 80"
A-1. The pressure belt unit reaches to its life ->
replace the pressure belt unit
A-2. Faulty fixing unit drive gear -> replace the
gear
A-3. Fault fixing motor (M48)
B. In case that the current value is "80 and larger"
B-1. Faulty fixing unit drive gear -> replace the
gear
B-2. Faulty fixing motor (M48) -> replace the fixing
mtoor
B-3. Fault relay PCB -> replace it
2. Clear the current value log of fixing motor on the
service mode (COPIER> FUNCTION> CLEAR> FX-LCLR)
after procedure.
Apr 12, 2016 | Canon Office Equipment & Supplies
How to fix toshiba bsa4tp ribbon error
The ribbon error may have different origins:-
- check that the winding is externe.
- Check that the ribbon core is fitted corectly.
- Check that you selected thermal printing in the driver.
- Check tha the size of the label is correct and that the interval between label is correctly propgramed.
heck that the the value of the ribbon motors is not set to -15.
Apr 27, 2014 | Toshiba TEC B-472 Thermal Label Printer
Ribbon error on B-EX4T1 with direct thermal labels
First of all, With any Toshiba label printer, after a parameter reset, you must send a label before doing a feed. Otherwise the printer will try to feed the ribbon.
You can use the setting tool to tell set the printer to direct thermal also.
Easiest way is to use the windows driver , add a label format coresponding to the one you are using, verify in the support tab that you are in direct thermal, do a test test print from the driver and you'll solve your problem
Apr 17, 2014 | Toshiba TEC Office Equipment & Supplies
Ribbon error /paper jam
probaly due to a wrong mounting of the labels and the transfer films
Nov 05, 2013 | Toshiba TEC B-572 Printer
Showing Ribbon Fault
hi
clean the ribbon then if still same error chang the ribbon
Jun 19, 2011 | Tally 6312 Matrix Printer
System error showing on my toshiba tech sx4
Download a new firmware.
- check that the antiparasite cores are mounted on the ribbon motor cables
Mar 16, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Label prints a tiny amount thenstops and displays ribbon error. Have rebooted the system and the printer (on/off).
Ribbon error: Remove the left side cover, and clean the ribbon motor sensor, located behind the plate that holds motors.
Dec 04, 2009 | Toshiba TEC B-472 Thermal Label Printer
Ribbon failure
Not wright installed. Only Course
Jul 11, 2009 | Tally 6306 Matrix Printer
RIBBON ERRORS
Mar 02, 2009 | Toshiba TEC BSX5 Thermal Label Printer
43 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
