Question about Toshiba Televison & Video
I have a toshiba prjection tv with no remote,i have a mydarkweb 6 device universal remote how do i get the codes so this remote works this tv ?
    Top Expert:
  • Toshiba Master
  • 66,248 Answers
ASK GOOGLE FOR THE REMOTE CODE LIST
Posted on Nov 25, 2019
6ya staff
SOURCE:
AvioriX
ExpressFiX
  • 689 Answers
SOURCE: philips universal remote code for direct tv.
I have a code table for you, you may try this if its different than yours. Here is the direct link (You need Adobe Reader to open it)
Good Luck
Posted on Dec 29, 2007
freetek
Steve Allison
  • 5569 Answers
SOURCE: toshiba tv code for Zenith remote
Check the manual for your Zenith; many of the Zeniths (and many others) have a 'scan' mode you can call up, in which you can repeatedly press one key (^ for example), then the Power Button. That will force the remote to set every code it has available, step by step.
If you no longer have the manual, you may find it here or several other sites that offer these.
Posted on Apr 09, 2008
Anonymous
SOURCE: philips universal remote codes for symphonics tv
Manually turn on the device you want to control
1. press and hold the CODE SEARCH button til the light stays on release the code search button
2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
(the red light will blink off after each time the channel up button is pressed )
4 Press the MUTE button to set the code
hope this helps
Posted on Nov 28, 2008
PABLOCSA
Pablo Csaky
  • 1124 Answers
SOURCE: Universal Remote Codes
Try, 0045, 0043, 0845 or 0154, 0156, 0060
Posted on Feb 03, 2009
Anonymous
SOURCE: tv codes for a rca universal remote controller
need remote control codes for a toshiba 32A35 with a rca remote
Posted on Jun 24, 2009
What are codes for a Toshiba TV and a Samsung DVD player?
The Toshiba TV could be 105, 162, 160, 161, 049, 072, 109, or 118.
You can use the CODE SEARCH feature of your RCA universal remote to find a code that will work with the Samsung DVD player.
Dec 28, 2015 | RCA 3-Device Universal Remote with...
I need the remote code for the tv: Toshiba 20af46c. Will a universal remote work with this tv?
0038,0032,0036,0030. Try these codes. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 21, 2013 | Toshiba 20AF46 20" TV
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
Jul 06, 2011 | RCA Televison & Video
I need a code for a RCA universal remote and a SEARS tv.
RCA
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Mar 13, 2011 | RCA Televison & Video
Cod for poloroid tv
  • Try to use tv codes for Mitsubishi tv
  • Toshiba code 678 works for a Polaroid TV model FLM-1514B on the universal remote function of my Dishnetwork remote.
  • THE UEI TV code for polaroid tv/dvd combo is 1991. The dvd code equivalent of that code is dvd 1480.
  • Here's the technical info for each of those Polaroid TV codes.
0019 = NEC1, device code 4
0054 = RC-5, device codes 0 and 3
0150 = Mits, device code 71
0178 = NEC1, device code 4
0765 = NEC1, device code 64
1256 = NEC1, device code 64
1276 = $0057, device code 71
Feb 20, 2011 | Radio Shack 15-2200 Remote Control
Uneiversal Remote Code
The model of the TV is not important as the code list is by Make only and usually list 3 ot 6 codes to try for each make. Having the Remote control model number is more important so you can find the right instructions and code for your remote.
Check here
Feb 18, 2009 | Toshiba MW20H63 TV
I am thinking of purchasing a universal remote to handle my Direct TV, Toshiba TV and Curtis DVD. Is there a code for a universal remote that can be used on the Direct TV? Gary Stroble
You can use the Directv remote to control all those devices.
Curtis DVD code; 21087
Toshiba TV code: 10156 11656 11256 11356 10650 10060 10154 10765 10178.
Dec 18, 2008 | Universal Remote Control DIRECTV Universal...
Can't find code for my RCR312W to work on my Toshiba TV. I tried all different codes. Any suggestions?
Have you tried these codes?
Code 1000 for Toshiba TV Code 1048 for Toshiba TV Code 1072 for Toshiba TV Code 1105 for Toshiba TV Code 1109 for Toshiba TV Code 1118 for Toshiba TV Code 1160 for Toshiba TV Code 1190 for Toshiba TV Code 1241 for Toshiba TV
Sep 10, 2008 | RCA Universal Remote Control
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
Need code or code search proceedure for Advent RC-S11-0A remote
Most Universals work similar for code search, try this on yours. [list] [1] Manually turn on the device (eg TV) [2] Press & hold Code button until indicator light stays on (or blinks on some) release Search button. [3] Press & release device button (eg TV). The indicator should blink off. [4] Point Remote at device (eg TV). [5] Press the Power button on/off down until the device turns off. [6] Press the ENTER button or OK button to save the code as soon as the device shuts off. (Suggest you have a finger on it for fast response.) Hope this works for you.
May 12, 2007 | Recoton Advent Advent RCS110A Remote...
Televison & Video Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
