How do you disable?
Speaker B and Mode buttons held down simultaneously while engaging master power, unlocked my DRA-397. Thanks!!!!
Love you guys!!!!!! B button and Mute button held down, turned on power and held buttons in until power completely on and.....
VICTORY!!! Thank you!
My remote is lock how do i unlock it
? please help
This thing is so dang complicated
Try holding down both speaker A and speaker B buttons then turning the power on. Alternately you can try holding down speaker B and Mode buttons while turning on the power.
SOURCE: Panel Lock On. How can I turn it off?
make sure unit is off then hold down spker b and mode buttons and then turn it on
SOURCE: I HAVE A DENON DRA-397
Make sure you are using the main power button not the standby button and you should be fine
SOURCE: Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button. This should unlock the panel....it worked for me.
SOURCE: remote lock on my denon
Hi.
Here the unlock procedure:
If that does not work, then firmware is defective. In that case you will need to contact Denon. The firmware is not available online.
Try performing the procedure, in ordinary conditions this should unlock the unit.
Regards.
Ginko.
Mt Denon receiver says "Panel LocK On". How do I turn it on?
