If I remember correctly, the error code means that your laser is not working correctly. When the copier is "ON" will it make a load humming noise? You will most likely have to replace the laser polygon mirror motor. It is not that hard to replace and you can buy it on line.... Basicly how much do you like the copier? It may not pay to repair it. I would look up the part price..... Good Luck
hello, F2 04 Improper cartridge (destination error, life cycle error). Try to put back the old cartridge , see if F2 dissapears, or try to put in a new one. the toner cartridge seems to be the problem.
L6 10 Content Polygon motor lock detected
Detail It was judged that there is no output of
polygon motor lock signal of LSU.
The lock signal was checked at about
10-second intervals after the polygon
motor started rotating. As result, it was
judged that the polygon motor failed to
operate normally.
Cause Disconnected connecter to LSU or
detached harness inside LSU or broken
wire.
Polygon motor defective
Check
and
remedy
Check polygon motor operation with
SIM61-1.
Check harness and connector for
connection. Replace LSU if needed
