I VE GOT ACER X221W HAD IT SINCE 1 YEAR .. MY PROBLEM IS MY SCREEN WENT BLANK THIS MORNING SEEMS TO ME NO POWER LIGHTS COMING ON. I USED THE PLUG WITH OTHER SCREENS ITS WORKIN OK.
The battery is probably dead. There is a guy on ebay that is replacing them. He fixed mine and it works great. The batteries dont last forever and you cannot just buy them they are a special type, also viper suggests you buy a new remote for $299 because they do not replace the batteries... how convenient. Hopefully that helps.
currently on a trip in Europe and when I went to shoot this morning, I
can only capture 1/3 of the area I'm shooting. That is everything in
the lower 2/3 of the screen is black. I've tried a couple of lenses
with no avail. Viewing previous pics is not a problem, so this is
obviously not a screen problem. I'm thinking something with the
mirrors? Any suggestionns for further detail visit this website http://newsallworld.com/
Sounds like you have gotten stuck in presentation mode. Hold down the function Key (Fn) its blue, and then hit the (F5) key once. If the screen doesn't come back, press both again.
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
This may be because your monitor is not connected to your PC or has a faulty connection -make sure the screws at the back of your computer are fully screwed in
Hi this is the way how to examine what's wrong with your LCD
monitors. Power on both CPU and monitor. After it went dim and blank, you have to
check if you can see the image on the screen or not by shining a flashlight into the
screen, not directly but find the best angle to the screen and take a look very
closely. If you can see the icons or any image, there will be a minor problem.
Like me, I can see window image using flashlight and check lamps inside. Some
of them were broken and it is easily replaced. If you cannot see anything on
the screen, there'll be some problems with inverter board. If you have
soldering tool and want to fix it by yourself, check the caps first. It may
cause this problem. Some caps might show leaking or burn spot on the board
because of too high temp. If you don't have soldering tool, you better go get a
technician to do so.
