Cell Phones Logo
Posted on Aug 19, 2009
My daughter has an Samsung schr 450 which thinks it is on silent all the time. When the volume is turned up it just goes to vibrate. cannot listen tomp3 tracks or ring tones
  • steve_street Oct 16, 2009
    Hi everyone the phone is fixed thanks the answer is to hold the # key but you need to use the side button to get the volume to display first. Then when you press and hold the sound comes back.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
93
Points
Have you checked to see if it is in silent mode? hold the # key and see if it fixes your problem.
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Aug 23, 2009
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
8558
Points
80
Your daughter phone speaker is broken,replace the speaker
Reset schr 880 cell phone
Here is how to perform Samsung SCH-R880 hard reset:
1. Turn off the phone
2. Press and hold the volume down key, the power key and the navigation key at the same time until you see a black screen with blue writing
3. Use the volume keys to select the factory reset.
Hello there,i have a samsung cell phone model SCH-R351.My phone is on silent mode.What can i do to get it off silent mode and turn the ringer on
In the Settings menu, select Sounds. The Sounds menu appears in the display.
Select the Master Volume sub-menu which allows you to set the default volume for incoming
calls, messages and alarms. You can set the volume to Silence All, Vibrate, Low, Low/Medium, Medium, Medium/High, or High. The Vib. on soft key allows you select vibrate in addition to the sound.
Hope this helps. If so, please rate this solution.
-best regards,
M
Mar 10, 2011 • Cell Phones
HI i have a Samsung 450 and i cant get it off silent mode for the life of me?!
u have to go into settings / sounds / volume and some times into advanced
2helpful
How do you activate the vibrate function on a Samsung u430 cell phone. the manual does not appear to have a section covering that process Thank You in advance H.P.Hudson
You can turn on vibrate 2 different ways
Either turn the volume down using the side buttons. It will eventually go into vibrate mode
Or just flip open the phone and hold down the * key (bottom left button) for 2 seconds. The phone will enter silent mode and vibrate.
9helpful
My phone is stuck on vibrate. How do I turn up
Try holding down the number sign, #, until it says "Exit Silent Mode".
1helpful
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
My phone is on silent mode, how do i get it back to ring mode?
Go to your sound option under settings, and there should be an option for SOUND, you should be able to increase, the volume there, Let me know how it goes, thanks
Justin
Please Rate Me :)
Jan 16, 2009 • Nextel i836
Hi Does anyone know if you are able to set the ringtone to silent and also the incoming message tone to silent (need it for work) on the Samsung F480 Thanks Elkay
In order to set the ring tone to silent you must turn the volume down to silent or vibrate. Go to phone in menu and check on sounds.
Silent Turn-On
Hi:
Before turning your phone off each time, reduce your phone's volume to 'Silent'. Each time you turn your phone on, the tone will not sound. Once you turn your phone on again, raise the volume again to hear the ring tone. You can also leave the volume in the 'Vibrate' mode, and it will vibrate each time you turn it off or on.
Tgillen4
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
