Question about Motorola Cell Phones
My motorola phone seemed to lock up so I powered it off to reboot and now it won't come back on.
Many pattern lock attampt but no benefit kindly guide me how to unlock motorola xt-502
Hi Sohil,
Sadly, if you're unable to get past the lock pattern, you'll have to perform a factory reset. Please follow the steps below to factory reset your device. Keep in mind this will delete all content from the phone.
  • Power off the device
  • Press and hold the R and M keys while pressing the Power button. You will see the red M logo on your screen then the screen with the Android-bot and a blue exclamation mark inside a white triangle
  • Once this screen appears, press both Volume Up and Down keys, then release to get the Android system recovery
  • Use the Volume Up and Volume down buttons to select wipe data/factory reset
  • Choose Yes -- delete all user data to confirm that you would like to wipe all data from the device and press the Return key
  • Your device should now cycle through the wiping/reset process and return to the Android system recovery screen
  • After userdata is cleared, the "reboot system now" option will be highlighted by default. Press the return key to power off/on your device
  • It will take a few moments to arrive at the initial Android Welcome screen.
  • Your phone will reboot and be back to factory settings. You can now set everything back up on your phone again.
    Thank you,
    Tom
    Motorola Support
    MOTOROLA PRO PLUS Factory Data Reset
    May 26, 2014 | Motorola Mobility XT3 QUENCH XT502 3.2MP...
    Error codes droid ultra
    Hold the down volume and the power button. That will force a reboot or a battery pull.
    Apr 30, 2014 | Motorola Cell Phones
    My motorola rival won't come out of slider mode
    You have a short from getting it wet. You need to make sure it is completely dry before powering it on and do a factory reboot on it.
    I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
    Oct 29, 2012 | Motorola Mobility Rival A455 Cell Phone
    My inspire seems to be locked on one screen that has a red triangle with an exclamation running through it. The phone will not shut down. It is frozen.
    It is the boot rom menu for the device. Just power it off then back on. IF it comes back then your OS on your phone is toast.It means your phone is in recovery mode. Hold down the volume up and power button at the same time, then select the option to reboot by going up or down with the volume keys and pressing the power button to confirm your selection.
    Dec 06, 2011 | HTC Inspire 4G Smartphone
    Phone need to be reboot
    dear sir or madam to reboot your motorola droid all that you have to do is hold down the power button until a menu pops up, select power off and then select ok the phone will shut down then once the screen is black hold down the power button until the motorola logo appears on the screen release the power button. in about 30 seconds your phone will show the lock screen. good luck!
    Aug 31, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
    MY FRIEND JUST GAVE ME HER OLD PHONE WHICH IS A MOTOROLA MB300. BUT THE PHONE HAS A PATTERN LOCK BUT SHE FORGOT WHAT IT IS. CAN SOMEONE HELP ME?
    Welcome to Fixya. If the you don't know the lock code you can try the steps below so that you can reset the phone to it's factory state.
    1. Power off phone. 2. Hold camera button and power on phone at the same time. 3. Release the camera button when prompted to. 4. You will see a message screen telling you to press the up or down volume button 5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed') 6. When triangle and phone screen appears 7. Press on the screen just above the back key 8. You will now see the "Motorola system recovery" menu
    At this point you will have three choices:
    1. reboot system now [Menu+Back] 2. apply ssdcrad:update.zip [Alt+S] 3. wipedata/factory reset [Alt+W]
    Select the third option to do a factory reset.
    Thanks You can simply tap an item to select it.
    Aug 02, 2011 | Cell Phones
    I need to master reset may Motorola Blur
    To Hard Reset the Motorola BLUR MB300 quite differs from other Motorola ANDROID phones.
    Do back up all your data stored on your device before doing this procedure, this process will delete all the data on the phone but does not delete the data stored on the microSD memory card.
    To hard reset Motorola BLUR MB300
    1. Power off phone.
    At the bottom of the screen you can select OK to apply your choice from the menu.
    There is also an opportunity to select Hide on the bottom left, I don't know what that does (I tried it and nothing happened).
    Selecting Wipe data/factory reset and tapping Ok and the screen changes to a box and a phone (Get it - out of the box) and you see what is happening on the phone.
    pick 2
    -- Wiping data...
    Formatting DATA:...
    Formatting CACHE:...
    Data Wipe Complete.
    Press Menu+Back to reboot
    pressing Menu+Back did nothing for me so I tapped 'reboot system now' on the menu and Ok.
    The phone restart then will restore back to its factory default state.
    Mar 20, 2011 | Motorola Cell Phones
    My backflip is locked and i forgot my blur info , how do I reset/unlock my phone ?
    1. Power off the phone, press and hold camera button ( do not release), press power button until phone turns on.Release power button while holding camera button down.
    2. Release the camera button when prompted (following the Batwings boot screen).
    3. Press the volume down button and wait for 15 seconds for a "triangle !" to appear on the screen. ( message "volume up key pressed " will appear )
    4. With flip closed, tap bottom right corner of darkened display (just above back button).
    5. Select "wipe data / factory reset" on screen
    6. Press "Ok". Wait for "data wipe complete" message to appear
    7. Press "reboot system now"
    8. Press "Ok" . Phone will reboot and complete master reset function
    Notes:
    Dec 05, 2010 | Motorola Mobility Backflip Smartphone
    Motorola razr keypad seems locked???
    It seems your Keypad Flex is messed up. common issue on the v3 - we can fix this for you - $25+ shipping
    http://horizonwirelessonline.com
    Jan 21, 2008 | Motorola Mobility RAZR Cellular Phone
    Cell Phones Logo
    41 people viewed this question
    Top Motorola Cell Phones Experts
    Ekse
    RONALD CARTER JR
    Zaid Anarwala
    Zaid Anarwala
    Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
