Canon PowerShot G9 Digital Camera Logo
Posted on Aug 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
While filming the camera just stopped and turned off but the lense was still on. ithought it was the battery so fully charged the battery but camera won't turn back on :(
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Oct 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
3683
Points
34
Most of the time this is from loose screws inside the camera that cause a short and leave the camera useless with a no power problem. For help with this, you'll need to have it fixed which generally requires a part be replaced. Try this site: www.camerasandparts.com They just service the Powershots exclusively and they are very familiar with this problem. It runs $89 all in for parts, labor and shipping back, plus they include the service for the camera too and even the shipping back. The big plus with them is they do the no power correction so the screws don't come loose again. A great place if you need help with a Canon Powershot.
Anonymous
Level 2:
Sergeant:
  • Expert 246 Answers
  • Posted on Aug 19, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
246
Questions
0
Helped
102632
Points
760
I would like to say that the fallen screws shorted the circurit board. More details see Who killed my G9?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
100
Points
No a solution, but questions. Can you view the images that are on the memory card? Does the lens retract? Does a fully charged battery go dead after being left in the camera, even with the camera off?
1helpful
Pentax K2000 DSLR stopped working after using manual K-mount lenses?
Have a look on Pentax Forums as a guest - you may find something there
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
1helpful
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Film is not winding on fully
Possible that the loading motor is having friction to load fully or that the film reel is too tight.
You can check the test without the film in place but by activation of the door switch.
If the reel pressure is good ,then the film reel might be badd or if the hand pressure stops the reel then the motor might be weak.
Hope the battery is charged. if not used recently let it run winding up to free.
I turned my camera on and the battery was too low so when it shut itself off the lense didnt go back in, now i've charged it and the lense is still stuck out. how to i get it back in so my camera will work
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
5helpful
2answers
Turn the power off and on again
1helpful
Lens keep extended in an out
3helpful
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
1helpful
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 • Photography
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
