After replacement of lamp, turn on TV, press and hold Volume Down button on TV front and press and hold Split/ Play button on TV remote at same time for 6 seconds.
That will reset lamp timer and confirmation display will come at TV screen.
Above info are also available in original Panasonic replacement Lamp box.
The exact procedure for this is outlined in the owner's manual. Also, it may come with the lamp. These lamps have expected lifetimes where they will output the correct amount of light. There is an internal timer that keep track of lamp time. The intent here is to replace the lamp before it fails. It is up to you whether or not you replace the lamp when the indicator says to change it. At the very least, purchase a lamp to have ready if the current one fails. Some lamps will fail before the timer indicates replacement time, others will work for many hours after that timer expires. There is no way to tell. Each lamp is a bit different.
If you can not locate the owner's manual, please update this to confirm your model number and I'll locate the sequence for you.
Dan
What if I don't have the original remote? I have a comcast universal remote, is there something on that I can use?
We purchased this tv used without a remote. We just replaced the bulb and now after a few minutes it goes dark but sound is still on and there is a message to replace bulb or resent meter...can we do this without the remote?
