Televison & Video Logo
Posted on Aug 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Image on top half of screen is gone. It seems to
Image on top half of screen is gone. It seems to have condensed to a think line in centre but bottom half of image is fine. Do you know what is wrong?
Anonymous
Level 2:
  • Expert 375 Answers
  • Posted on Aug 20, 2009
Anonymous
Expert
Level 2:
Answers
375
Questions
0
Helped
156320
Points
973
The LCD inside the projection unit is broken - nothing you can do about it - it needs replacing.
They are built in two halves to give you higher resolution and quick image response. One is working, the other is broken. You will need to get it serviced.
1helpful
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
1helpful
Thin vertical blue ink bleed line from bottom of Malaprop screen - Fades over time
Yes, it's a screen problem. It could be a loose connection of the LCD and the motherboard or the lid lights gone bad. You can fix that by either resetting the connection of the screen and the motherboard or replacing the whole screen. You would need a technician to do that.
David
1helpful
Plasma tv problems
Thanks for the photos, it looks like an internal adjustment is required to the ramp generator which controls the sequence for the screen to refresh itself from a previous image to a new image. This is a precise setting & also a software update may be necessary to cure the problem. These settings are on the Y-Sutain board & need to be accurate.If this procedure does not cure the problem then the screen will need replacing. As it will out of warranty, it would be best to contact a local repair centre & ask for an estimate to try & set these adjustments for you.
2002 27" SONY Trinitron. Half-screen picture with bright line.
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
RCA PHD50300 no picture on top half of screen
Replace the scan drive board also called X-sustain board. This is the board on the upper left side in the back of the set with a huge heat sink on it. you can find them online for about 175.00. The p/n is pkg50c2g1. Be carefull with the 4 ribbon connectors that go to the display.
2answers
Vertical line in centre of my zenith plasma p60w26 tv
I also have this problem, but with 2 black vertical lines on the right side of screen half way through. Lines disappear from time to time but reappear. Is there anything I can do to get rid of them. Help me out please
.... Thank You.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
