Better Stellar Phoenix Excel Recovery which can fix corrupt Excel (.XLS/.XLSX) files and restore everything (including charts, chartsheets, cell comments, worksheet properties etc.
Best utility which efficiently and instantly Excel file recovery tool.This software scans the spreadsheet to recover maximum possible data instantly. User can easily download the trial version of Excel recovery software from here :-
Excel File Recovery Software
I suggest you for third party software like RecoveryFix for Repair Excel File software. This software is the powerful Excel file recovery utility to recover damaged Excel spreadsheets data. Excel File repair software Compatible to all kinds of word documents file formats.
http://www.excelrepairtool.com/
You may fix your excel file only using recovery function, if MS Excel can't help try excel fix in some steps of its recovery wizard gives back your excel file to proper condition working under Windows 98 and later.
If you are using Office 2007, there's compatibility software offered by microsoft, otherwise try a data recovery software.. sodeep
Use in-build "open and repair"utility of MS excel to repair damaged .xlsx files. Follow thesesteps to it
On the File menu, click Open.
In the Open dialog box, select the file you want to open, and click the arrow next to the Open button.
Click Open and Repair, and then choose which method you want to use to recover your workbook.
Most probably your problem may get fixsuppose due to any reason it can't fix your problem then use thirdparty excel repair softwarehttp://www.stellarinfo.com/excel-recovery.htm
