You probably tried taking the battery out and using an eraser, clean the terminals of the battery, replace do not power phone on, plug in charger and see what happens.
try taking the battery out and while holding the power button in put the battery back in, if you still get nothing on the screen try doing the same , holding the power button down while you insert the charger.
If a tri coloured screen appears you will be able to reflash it, if it doesnt appear, then your battery is dead and it wont charge no matter how much you try, the MDA(or wizard) wont charge the battery, unless windows is running, i would recommend you buy a new battery, they are cheap enough
NOTE!!! If the battery is very low but you can get the multicoloured bootscreen, i would not advise flashing it as you have no idea of how much charge is in the battery, if the battery fails during flashing you wont have a phone anymore
It appears that the phone is not charging the battery. you may need a new charging connector or mainboard repair. You can get a free repair diagnosis and estimate from www.fixphonenow.com cell phone repair services.
This might be a hardware problem with cell, Before you buy a new battery, swap it with another. If that works, perfect.
Unless it's defective motherboard or you might have blown certain Ic's that you need to get it fixed.Ic's might be repaired even by yourself, However if motherboard is at fault you might need to pay half the amount of the cell :(
Anyway, i have given you all the steps.
Note - I am taking into consideration that your charger is fine.
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone. Razr V3 external battery charger
I had this same problem a couple of months ago, battery appeared to be charging but got emptier and emptier, tried different chargers and no improvement etc.
Friend has same phone, used their battery in my phone which was charged and phone was working fine, meanwhile, charged my battery in their phone and it charged fine and then for 2 months no repeat of the problem...
then last week, it happened again, trouble is this time i'm on school holidays and can't use the friend's phone for another 3 weeks!
If you replaced it with a working new battery pack. You can test it in another phone. The Battery pins on the phone board could have a poor connection which requires soldering.
my sidekick 3 wont turn on at all,, it charges but when i go to turn it on. nothing.. how can it get fixed or wat kind of profesional help could i get to fix it?
