PAV2300 Top Load Washer This washing machine tutorial will show you what to do if
the washing machine does not drain or empty the water out this repair was done
on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated
for answering your FREE question.
If you here motor run you probably have a broke coupler between tub and motor or a broke belt if belt driven
if tub washes you have a cycle switch problem or other
must empty water and look under machine
not to hard to drop motor and replace coupler
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
SOURCE: Maytag Neptune washing machine - wont drain & spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
