Hi, my samsung U700 hp touch pad cant sensor ady, and it cant lead me into the menu. Now I only can accept phone call by slidding up. And the phone will always on.
IM STUCK ON PAGE WITH PHONE KEYPAD AND IT WILL NOT GO AWAY OR MOVE WHEN IM TRYING TO USE ITIM STUCK ON PAGE WITH PHONE KEYPAD AND IT WILL NOT GO AWAY OR MOVE WHEN IM TRYING TO USE IT
You can't post conmments that contain an email address.
If your touch screen is not working, there are just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
If your touch pad is not working, there's just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated. If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone. To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively. But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
Hope this helps you.
contact me & i will tell you how to fix it! email me ([email protected]). Why don't the so called experts give you the answer any answer because they want your money. they are all rip-offs!!!
