Question about Asko Washing Machines
F11 fault in asko washing machine. I check cleaned, clean screw out at the bottom. drained water removed half of the clothes and restarted. still F11 code???
  • BrandiJWimberly
    BrandiJWimberly Jul 08, 2019
    Making Cash more than $15k to $18k consistently just by doing basic online work. I have gotten $18376 a month ago just by working on the web. Its a simple and basic occupation to do from home and its profit are greatly improved than customary office work. Each individual can join this activity now just by pursue this link........go to this site home media tech tab for more detail support your heart :*
    HERE? ­­ www.profitclip.com
Anonymous
SOURCE:
gittos73
peter gittos
  • 247 Answers
SOURCE: Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Posted on Aug 22, 2007
Anonymous
  • 66 Answers
SOURCE: Water won't drain
make sure there is power getting to the pump if so then your pump has stopped working or may be blocked if not than it will most likly be your pcb
Posted on Sep 14, 2007
Donn Roth
  • 6 Answers
SOURCE: aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Posted on Jan 14, 2008
Anonymous
  • 156 Answers
SOURCE: spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Posted on Feb 25, 2008
johnychel
isaac johny
  • 796 Answers
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
Asko W6021 Front Load Washer error detected "F3 Outlet Blocked". How to solve this problem?
The drain access is at the bottom left of the washer. Insert a screw driver in the right side of the cut-out and and gently pry open. Open the drain pump. You will need a small container and a towel to help catch the water that will be coming out. After letting all the water out, clean out any objects in the drain pump. After cleaning out drain pump, put everything back together and restart washer.
Feb 05, 2011 | Asko W6021 Front Load Washer
The machine is not draining water - it starts the washing cycle, takes in the powder and churns around but then stops when it needs to drain the water. If I empty all the water out, it will then spin the...
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Asko W6021 Front Load Washer
I WANT TO CLEAN OUT THE FILTERS BUT CAN'T FIND THEM. tHE WASHING MACHINE IS 3 YEARS OLD AND IS WORKING BUT IS A BIT SMELLY AND CLOTHES ARE NOT AS CLEAN. I USE REAL NAPPIES AND USE THE MACHINE DAILY SO IT'S...
Remove lowwer rrear panel. locate and remove the large black hose fastened to bottom of drum, there should be a plastic filter inside the hose, if not, then filter is located at bottom front right of washer behind cover.
Sep 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do you open the door, and how do you get the clothes not sopping wet when the wash cycle is done?
HI- If the clothes are coming out wet then there is either a problem with the spin cycle or drain pump. The door won't open if the washer senses there is too much water in the machine. Try doing a dedicated spin again the see if the door will open. Your drain pump may also be clogged. There is a little door at the bottom front of the machine. Open this (pry carefully open with a butter knife) and you will see a plastic plug that can be unscrewed (counter clockwise), this is the pump filter. Be prepared to catch the water that will come out with a pan and have some towels ready, sometimes there is a lot of water. Once you get the filter out clean it out and check for any loose change inside the pump. Screw it back in carefully and tight and be careful not to strip the threads. Run a rinse and spin once it's all back together and see if it drains ok. If it still is not draining you probably need a new pump. There are very few Asko Techs around so you may have some trouble getting someone out. As well, call Asko customer service, they have really good techs that can help you over the phone. Good luck.
Sep 23, 2010 | Asko W6021 Front Load Washer
Asko washing machine won't drain.
Further on to this F3 problem I had the issue on model W6461. There is a short cut to the fix, instead of taking off the grey pipe from the drain pump (the hose clips are pre crimped in the factory so as stated above are difficult to remove) try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear through back the coin trap.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water.
Just ran the machine now and fault cleared.
Good luck
Jurgo
Apr 30, 2010 | Asko W660
Wont drain water Gorenje WA61111
locate the filter and clean, this should cure
Dec 16, 2009 | Asko W600
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Aeg 72630 update will not rinse during rinse cycle
if is an asko remove the top panel and check the triple valve for a faulty solenoid,also remove paddle from inside the drum with a screwdriver in the middle hole and pull toward you,and look inside the black sump hose to see if theres a plastic ball in the hose if so you need to remove it take of front panel/s to get access to the hose.also check for coins in the hoses acting like a valve.let me know and i will think of somthing else
Mar 25, 2008 | Asko W6761 Front Load Washer
Fault Indication - "Over Flow"
Does manual say to clear drain by running high temp water to clear drain; i dont think so. Now you have to unscrew the back to see where the leak comes from - by pouring plain water into the machine (where u put clothes). Unplug all electrical connections, ie disconnect the machine from the wall socket. Pl post back
Apr 18, 2007 | Asko W6761 Front Load Washer
problem may be to with using very hot water which has dislodged sludge. fault may cure itself.at top of machine is a usually round device with 3 to 7 wires to it depending on type used. also connected is a small diameter hose. trace this hose to bottom of machine and it is connected into an air chamber. check air chamber is not clogged with sludge and if it is, clean it. remove small diameter hose and check not clogged as well and that there are no splits with it. there is really no need to clean appliance at all unless you are using liquid detergent which over time leaves a smell like drains. if you are, recommmend using powder
Apr 18, 2007 | Asko W6461 Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
