The malibu output is generally for AC power ... but LEDs run off DC ... check your manual on following link
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
SOURCE: How do you set the timer on Malibu 300 watt
Make sure there is power to the plug. Then set the clock and install the on and off pins to control the lights. The on/off switch is for manually turning on the lights. The clock should run as soon as it's plugged in.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: i have an ads power plate amp, im not sure what
i have a p450 powerplate by ads i cant figure out how to hook up the power and ground does it have a plug type thing that maybe im missin help me
SOURCE: my microwave cooktop lights keep burning out. why?
Are you keeping them on all the time?
Or is the the microwave subject to excessive vibration or door slamming while the lights are on?
Both these conditions are factors in premature bulb failure.
I would also avoid cheap Chinese bulbs from grocery stores and get the GE-specified bulbs either from here online or a local home center such as Lowe's or Home Depot. etc.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Replacement of on/off trippers for intermatic low voltage timers
These should work:
http://www.nextag.com/timer-trippers/shop-html
SOURCE: Malibu 300-Watt Low Voltage Transformer ML300RTW Not Functioning
My power went off at my house. After it came by on how do I reset the transformer to come on automatically?
