Question about Great Office Equipment & Supplies
Can anyone help me with my SUV it's a great wall naval h5 it has a code error p1404
6ya staff
SOURCE:
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Posted on Dec 21, 2007
Everett Lin
  • 990 Answers
SOURCE: error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Posted on Apr 14, 2009
Anonymous
  • 62 Answers
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out https://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Posted on Apr 15, 2009
MIAN
  • 87 Answers
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
Posted on May 09, 2009
Hardwork
  • 22 Answers
SOURCE: error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
Posted on Aug 13, 2009
How do i fix sharp copy machine AR5520N with error code H5?
H5 error is protection against big damage of the fuser caused by multiple paper jams in the fuser area. First clean and check paper way, check sensor operation and then reset the error. Reset with key operation # - INTERRUPT - CLEAR - INTERRUPT - 1 - 4 - START
Aug 14, 2016 | Sharp AR-5520N
WHAT IS ERROR CODE H5 FOR A FRIGIDAIRE HEAT/COOL WINDOW UNIT?
Thank you for your inquiry, Angela Babin!
From my understanding your Frigidaire air conditioner is displaying an error code "H5". Normally, the error code "H5" stands for heater thermistor error. I would recommend performing a reset on your air conditioner by unplugging it for ten minutes. If that does not help correct the error code it could be a possible problem with your thermistor or control board. I hope this is helpfully. -Matt
Nov 02, 2014 | Frigidaire Heating & Cooling
Not operating due to error code H5-01
I HAVE THIS SAME PROBLEM....IS THERE ANYONE WHO CAN HELP?! I REALLY NEED TO USE THE PRINTER IN THIS ERROR CODE IS PUTTING ME BEHIND AT WORK...PLEASE...
Aug 13, 2010 | Sharp AR-M455N Copier
ERROR CODE F2 00
improper cartridge (destination error,life cycle error
Jun 08, 2010 | Sharp AR-5320 Black and White Copier
H5 flashing on the display, anyone tell me what the error is please? It's a Sharp AR-161 copier
H5 doesn't show up on the service code manual. However, all error codes beginning with 'H' are related to the fuser, this is the heating portion of the machine. Be careful if it still prints despite the error code, you may damage the unit. It should be looked at by a service rep.
Jan 12, 2010 | Sharp AR-161 Laser Printer
Error code H5-01 sharp MX2300N
pascale_algu
Good Luck
Aug 13, 2009 | Sharp MX-2300N Color Copier
Error code H5-01
HI.H5-01
check its cable
reset this code
press ,p,*,clear,*
May 07, 2009 | Sharp AR-M350U Copier
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
Ar-c160
Dec 16, 2007 | Sharp AR-C160 Color Copier
16 people viewed this question
Top Great Office Equipment & Supplies Experts
Marvin
Marvin
Akbar Mughal
Akbar Mughal
Bill Boyd
Are you a Great Office Equipment and Supply Expert? Answer questions, earn points and help others
