SOURCE: Drain problem
I have the same problem and after talking (mostly waiting) with Fedders repair, I have been told how to solve the problem. Plug up the drain hole on the right side (the one not connected to the drain hose). The drain hole extends down about 5mm, outside measures 10mm and interior measures 7mm. They do come with a drain hold cover. Not a replaceable part with a number. Off to the hardware store.
SOURCE: permanent drain won't work
The pan itself should be sloped towards the back....ensure that the drain pan is installed correctly and that the hose or outlet fitting is not blocked . It will not do any harm to give it a little extra tilt especially if the floor isn't level
SOURCE: I have a Whirlpool Gold dehumidifier with the hose
I have a similar Whirlpool dehumidifier and a similar problem. Have you tried setting it to continuous mode? My understanding was that it would only divert the drainage to a side hose when in the continuous mode.
SOURCE: need instruction manual for Danby Silhouette
Well can't seem to find your particular model but they have what looks like yours
http://www.needinstructions.com/search/?q=Danby+DDR600R+Silhouetteumidifier+MANUAL&page=3
