Maytag Neptune MAH7500WH Front Load Washer Logo
Posted on Aug 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The washer buzzes and shows the fl and do on display when we try to start it this was after the door was opened during the cycle
Mark
Level 3:
President:
  • Master 704 Answers
  • Posted on Aug 22, 2009
Mark
Master
Level 3:
President:
Answers
704
Questions
0
Helped
592469
Points
2820
It appears that the door latch safety interlock was damaged or broken when the door was opened mid-cycle.
The codes "fl" Failure and "do" Door Open, seem to indicate that the latch and/or door switch need to be replaced. I tried to find a drawing and parts list for your washer, based on the model you selected, but could not locate one. If you can get the full model number, you can check for the replacement part at searspartsdirect.com or call them to get the part number.
If you look inside the door of the washer, you can see if the catch (on the moveable door) or the latch, on the washer cabinet) is the broken or damaged.
The repair is relatively straightforward and easy to do, with simple hand tools. Just make sure to disconnect the washer power cord before doing any work on it. Once you've done that, open the door and remove the screws and you should be able to remove either or both, the catch and the latch switch and reinstall the new ones, once you have them.
That should resolve the problem you're having.
Hope you find this Very Helpful and best regards!
1 Related Answer
Anonymous
  • Posted on Jan 01, 2010
SOURCE: washer makes a buzz noise shuts off displys do and fl
I used the recommendation of removing the soap dispenser area on top of the machine, under that area is a thin green nylon cord that when pulled will release the lock on the door of the machine and open it. after the door was opened it reset the machine and now is working fine.
Maytag Neptune code fl shows on display
The FL code indicates that the door failed to lock when you closed it. Try opening and closing the washer door again. Make sure that there is nothing in the door area that could block the latch or keep the door ajar. If the error recurs, the latch may be faulty.
If the door is actually locked and giving the FL code, the latch has a problem. You can try power-cycling the washer (unplug for a while) or setting the washer to pump the water out. If these steps don't help, you need to order a replacement latch assembly. Depending on your washer model, you may have a manual pull cord to unlock the door. Look under the bleach and fabric softener compartments after opening the dispenser..
I hope this helps. If your washer is under warranty, contact Maytag. Otherwise post a comment with the model number of your machine for a source for a replacement latch assembly.
1helpful
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
When trying to wash a load my washer is starting to fill and then shows the DO code "door open." when I shut it off the door will not unlock. I tried changing cycles and it is also showing an...
First of all, try unplugging it from the AC for about 30 Seconds. Then, plug it back in and wait 30 Seconds or a little more, to see if the Door unlocks. If it doesn't, find the Instructions that came with the Washer and look at the testing Procedures for your Machine. If you don't feel comfortable doing that, you may have to call for professional Help.
The "FL" Code probably means that the Motor isn't turning. You probably have a Board that is bad. The Troubleshooting Guide will help you determine if it is the Motor Control Board or the Main Board. Good Luck.
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
3helpful
2answers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
2helpful
Washer makes a buzz noise shuts off displys do and fl
Washer won't start, stopped at beginning of cycle and the door lock flashed. after about 5-6 flashes the display read: FL. Tryed to start again, unplugged it for a while several times. nothing happens....
FL:
Failed to lock.
Trigger:
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Action to be taken:
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
If you need to open the door.
Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
1) Remove the bezel from the soap/bleach/fabric softener dispenser.
neptopbezel.jpg 2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Best of luck, Any questions just ask
1helpful
My washer is making a buzzing sound and does not start making sound from where latch is will not release the door its staying locked . the code its showing is FL and DO.
if you open the dispenser door on top of the washer, and feel around the front you should find a little green ripcord. pull on the cord until the door releases. most likely the wax motor in your door latch is fried.
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
2answers
"FL" light
The "FL" error code indicates that the door is not locking. The buzzing sound you hear is most likely the door lock trying to lock the door. It may only be a matter of aligning the door so that it locks properly. Otherwise, you may have a faulty door lock that needs to be replaced.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
