Heating & Cooling Logo
Laurie Muldoon Shomo Posted on Jul 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Circuit breaker keeps tripping when the compressor comes on
Thomas Woodburn
Level 3:
  • Heating & Co... Master 2,638 Answers
  • Posted on Jul 06, 2019
Thomas Woodburn
Level 3:
Answers
2638
Questions
Helped
1251635
Points
7008
Compressor is likely shorted to ground. Turn breaker off, take the fan off and unplug the compressor. Put the fan back on and turn power back on with a call for cool. If fan runs and breaker holds the compressor is bad.
5 Related Answers
Anonymous
  • 290 Answers
  • Posted on Nov 20, 2007
SOURCE: Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Jimster
James Greene
  • 240 Answers
  • Posted on Feb 02, 2008
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Anonymous
  • 121 Answers
  • Posted on Apr 22, 2008
SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Anonymous
  • 63 Answers
  • Posted on Mar 20, 2009
SOURCE: Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Anonymous
  • 10865 Answers
  • Posted on May 02, 2009
SOURCE: Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
Taotao ate 501 breaker keeps tripping
breakers that keep tripping indicate a sever overload from a dead short ( same deal as a fuse)
It could be from a failed start/run capacitor for the compressor , vermin related problems or shorted wiring
best have a technician check it out
It is possible that the breaker is weak and tripping before the set current flow is reached ( a replacement of the same rating will prove this) Do not use a higher rated circuit breaker
4answers
What causes caravan aircon to trip circuit breaker on start up
Want to install split unit aircon in my caravan but see it only has a 16amp breaker, would this be able to run fridge, kettle and aircon at the same time?
Aug 30, 2014 • RVs
1helpful
Circuit breaker trips after water supply cycle
check the condensor fan in the compressor area and make sure its running if not the compressor will overheat causing high head pressures on the compressor causing it to draw too much current to operate the compressor and kick the breaker out,also make sure the condenser coils there are clean and it has ample air movement away from the wall
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Frig keeps overloading circuit breaker, just repaced relay
I think the compressor has a problem with its internal running coil , or it's grounded.To check it you can disconect the power to the compressor and then turn on the breaker , and if doesn't tripped the breaker ,you know the compressor is bad.
Tripping breaker
There is a short circuit in the fan motor or compressor most likely. Disconnect the common wire to the compressor and try again. If the fan comes on and the breaker does not trip you have a bad compressor or a bad wire touching somewhere. Also,check the capacitor. Is it bulgded out or a burned wire? Could be a bad capacitor.
2helpful
Keeps turnning off breaker
You may want to look at the circuit you are plugging this into. This may be pulling a load that is to much with everything else on the circuit and causing it to trip. Try to plug it into a bathroom circuit which should be rated at 20 amps and be of 12-2 wire and see if it trips that breaker or GFI. Let me know and I can help you from there.
6helpful
Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Top Heating & Cooling Experts
Paul Carew
john h
