Have a 42500btu minisplit 72000 btu indoor units 2@18000. 3@12000
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
SOURCE: my mini split does not run
Check that you are on the correct mode setting. Open the remote and press the mode button (the one with about four little icons, star, teardrop, triangle and sun) until you get to the mode you require. If cooling required, select the star or crystal, if heating required select the sun (circle with little lines)
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
SOURCE: installed new LG 18000 btu mini split heat pump,
a heat pump is a finely tuned machine that can be very efficient yet very frustrating at times. I could give you better advice if I were looking at the unit but hear are some things that may help. The unit has a defrost mode that cycles every 30,60,or 90 minutes. If you take the cover off of the condensing unit and near the top you will see the adjustor. unless you live in arctic or very humid cilimates, it should not be set to 30 min. Also the unit may be low on refrigerant. you can check this with a thermometer. put the therm. on the hot gas line(big one) and it should be 110 degrees hotter than the outside temp. Insulate the point of contact around the therm. and gas line. Also, your aux. heat may not be coming on to supplement the heat from the pump. i.e. the fusable link could have burned up and the heating element wouldnt be coming on(elec. models). there are too many variables and combinations of problems that could cause this.
SOURCE: lg 12000 btu air conditioner inverter is not
This alarm state is a CH 06 alarm.
Indication for the Indoor unit pipe temperature sensor (thermister) not plugged in or out of calibration.
This alarm will also occur when the unit gas charge is to low and the indoor unit temperature reached a temperature of -5°C for longer that 30 sec. It will switch the machine off.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
