Per my cable provider - I am unable to get an HDMI signal because the HDMI port is bad - I can access cable using s-video, composite, etc. it is only the HDMI signal that I cannot access, We were having storms in the area about the time the HDMI signal became unavailable. If it is a bad port, can it be replaced or can an external port be added?
I have Verizon Fios and there's a known issue with the motorola HD boxes that they have bad hdmi ports, the screen goes green and that's it, nothing I can do about it I just use component cables. You need to be sure it's your tv not the cable box. Try the hdmi on a dvd player or ps3 or whatever else you have first just to be sure it's the tv at fault not the cable box. If you determine it is the tv you need to replace either the main board or the video board depending on your specific tv model. Some have the video inputs on the main boards some have video boards.
1) Look at your laptop computer to see if
you have an HDMI cable port. This port is roughly half an inch wide and
provides both the HD audio and video signal. If you don't, you are going to use
a DVI port on the laptop. This is the same port you use to connect monitors to
your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the
Blu-ray player. If you have an HDMI port on your laptop, you can skip this
step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an
HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD
television. Power on your television, press the "Input" button and
select "HDMI." You can now see the contents from your Blu-ray player
on the TV.
Thanks for rating
Good luck
olevia 2327-S11
olevia 227-S11
This is the correct response - ignore my lasyt reply
Thanks
I have a 37" vizio full HDTV and everything was working fine then about w week ago the HDMI ports stopped reconizing my philips upconvert dvd player. I have tried turning it off and on and i get the same results says retrieving data and then goes to a blue screen, it works fine with the rca cables. I live in the basement of a house. What can I do to fix this?
what is the model # of the TV?
