My GE Harmony Electric Dryer starts out working okay with heat, but when I go back later to check on the load the screen says SENSING and the clothes are still wet. The load will be alike items....such as all towels.
Nicknames, usually with long dry times I suspect a pinched or clogged vent. Make sure you check that first. You can do a test to check the moisture sensor. The 2 sensor bars will be on the inside of the drum just below the vent cage. Press the home and then help button. Next press and hold the help and start/stop button for 3 seconds. On a dry sensor, you should see a voltage of approx 4.75 displaying. Now get a wet rag and hold them across the 2 sensor bars. You should see the voltage drop to about 1.0 volts. If it does this your sensor is ok. Check the vent and this out first and we will take it from there. Catriver.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
