Olevia 227-S11 27 in. LCD TV Logo
Posted on Aug 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need 5 Digit Remote code for Olevia 227 s11 and comcast remote
I tried codes in the remote manual .. but they dont work
Anonymous
Level 3:
  • Master 476 Answers
  • Posted on Aug 22, 2009
Anonymous
Master
Level 3:
Answers
476
Questions
0
Helped
101140
Points
1473
Mbhagdev, i've found that sometimes by using the remote code search procedure i have been able to program some hard to set brands either tv, vcr.dvd etc. try this procedure you'll find it in your set up manual for your universal remote, your other option would be to click the web page for the universal remote you are trying to program and give them the corresponding info to see if they can come up with an updated code for your olivia tv. good luck and thanks for leaving pos feed back if i answered your question.
How do I get channel scan on my olevia 227-s11 using the buttons on the tv instead of a remotr
If there is no button marked 'Menu' at the front panel of the TV; you can't re-tuner it without a remote control.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
1helpful
2answers
Need Comcast 5-digit universal remote code for Sony BDP-S3100
Find Your Comcast Remote Control Programming Code
make sure your using those codes with the AUX button. Comcast does not have all remote codes for every electronic made though.
Program remote for comcast
Check these codes: 11144, 11240, 11331
programmmming TVTV control
The Comcast DTA remote control is preprogrammed at the factory to operate the DTA receiver. The Comcast DTA remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold Setup until the Red Light blinks twice, then release Setup.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
3helpful
3answers
I can't program my Comcast remote for my Olevia model 232 S12, I have used all the codes comcast suggested to no avail
The Comcast remote will unlikely have Olevia codes available since its design age is much older than the set's. In addition, it may never have them since Olevia is bankrupt and probably of little interest to Comcast. You might check Comcast's website since the most recent codes will be available there.
5-digit universal remote code for olevia 532h
No such thing. Your best bet is to watch various deal sites and get one of the less expensive Logitech Harmony remotes, all of which can easily control your Olevia, as well as your set top box (cable or sat), DVD player, receiver and any of over 100,000 pieces of av equipment -- including eveyr product Olevia made before going defunct.
Remote doesn't control. batteries are good, but there is no apparent connection between the remote and the TV. It is in use with a Comcast turner-DVR, which works fine, but I have to turn on and adjust...
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
What is code for Olevia 42" TV, Product # 242-S11?
I have the Olevia 65 inch LCD TV and cannot find the comcast remote code for my TV! Any help?
1helpful
3answers
Olevia t.v.
try rca, lg, philips, yamaha these are compatible with olevia
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
