SOURCE: RCA systemlink 3 remote
My friend you gotta turn on manually your tv first.Then push and hold until the indicator light lights,then release the code search button now push and release the Tv button after that you gotta push and release the power button until the Tv turns off then you push the enter button to save the code.Good luck.
SOURCE: I have LG 50PC1DR plasma
Hi !..ok you tv problem is in power supply. need be replaced 9 capacitors, (3300mf - 10V) in main power supply board, that fix yu tv..
SOURCE: Viewsonic N2750w flashing different colors on screen
did you get any answers? I have the same problem.
SOURCE: funai lc195emx flat tv is
Hello
Your Funai Emerson TVs' video output section has damaged. You yourself can do nothi in it, as there must be sophisticated testing equipments to test and detect the reason for this problem. A common man can't afford its cost. So I advice you to get it repaired by some experienced service personal, who owns oscilliscope, colour scanner, signal generator, colour analizer and so on. In short, you have to rely on a well wquipped service center to get it repaired. OK.
SOURCE: I have a LG 55" smart TV and can not get the sound
get into your setting on your tv (menu) and click on the audio and make sure the speakers are in off position.
