Televison & Video Logo
Posted on Aug 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size bolts hold the wall mount bracket to the tv
  • smmis3 Aug 23, 2009
    It is a regza 42'' Toshiba. I found out that the book does not say what they are. But they are M6 bolts or 6mm about 3/4 of an inch long and toshiba does not send them with the tv's. Thankyou for the reply though I thought i would post this for any one else it took me about an hour of surching for the size and that included calling toshiba. Thankyou again,,
Anonymous
Level 2:
Novelist:
  • Expert 154 Answers
  • Posted on Aug 23, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
154
Questions
0
Helped
105539
Points
452
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5708
Points
For the Toshiba 47ZV650U tv, the botl size is 8mm course thread 1" bolt.
Chi Chu
Level 3:
  • Televison & ... Master 8,457 Answers
Chi Chu
Level 3:
Answers
8457
Questions
0
Helped
2822565
Points
26282
In ur package came with ur instructions,and a booklet manual it tell u.Or use 2" bolts i use
four 2" bolts in my wall mount.
5 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Dec 23, 2009
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Anonymous
  • 10865 Answers
  • Posted on May 02, 2009
SOURCE: 42LC7D-AB cant find bolts to fit for wall mount
http://www.scribd.com/doc/6399173/LGTV
here is the owner manual. look on page 16 and you will see one way to wall mount. Ragarding the size of the bolts needed, go to the hardware store and get one bolt of each size close to what u think u need and use the trial and error method. OR go to an electronics store and ask one of the techies. Be nice and they will help u for free.
Anonymous
  • 1284 Answers
  • Posted on Apr 18, 2007
SOURCE: What size bolts for mounting bracket??
I don't know the size but, I can bet it will be a metric bolt.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jul 05, 2010
SOURCE: bolt size
They are Metric screws, either M5 or M6, you can get them from hardware store for about 25 cents each, so get different length depend on the mounting brackets.
Wall mount usually comes with mounting screws already.
http://s807.photobucket.com/home/budm/allalbums
Chi Chu
  • 8457 Answers
  • Posted on Jun 30, 2011
SOURCE: I own a Samsung DLP
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
1helpful
2answers
I have a Wall bracket for the wall but the screws that hold the brackets to the back of tv r missing. If you could tell me what size or let me purchase them would be helpful.
Screws for Mounting TV to Wall Bracket:
The most common screw for securing the TV to the wall bracket is an M8 screw. The other screw sizes for some TVs are M4, M5, and M6. The length will be determined by the type of TV you have.
https://removeandreplace.com/2016/10/18/tv-wall-mounting-what-type-of-screws-do-i-need-from-wall-bracket-to-tv/
https://www.google.com/search?q=I+have+a+Wall+bracket+screw+size&tbm=isch&source=univ&sa=X&ved=2ahUKEwizwvWc7rroAhUDy4UKHTGTBW0Q420oA3oECAcQCQ&biw=1326&bih=627
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
2helpful
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
5helpful
2answers
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
1helpful
Bolt size
6helpful
Screw size to bolt panasonic 32 inch lcd into
1helpful
Dont know what size bolts to use for fixing brackets to tv to wall mount a 26 inch wharfdale l26ta6a
you should use minimum of 1/4" lag bolts by 2'" long.
Find a wall stud, and drive the bolts(one above the other into the wall through the mounting bracket holes.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
