What model hunter fan is it and so you know not all cieling fans change directionWhat model hunter fan is it and so you know not all cieling fans change direction
You can't post conmments that contain an email address.
you don't
Reverse direction for a ceiling fan is a clockwise motion producing an updraft. In the winter, when your heater is running, reversing your ceiling fan moves warm air near the ceiling down to the floor. This greatly reduces your energy use and can lower your energy bills by as much as 15 percent. You will need a ladder or a step stool to reach the motor housing. Turn off your ceiling fan and locate the direction switch on the motor housing. This one is here, sometimes they are on the top of the motor housing. Make sure your fan has come to a complete stop before flipping the direction switch in the opposite direction
You cannot do this because the remote has a connection for reversing the direction of the blades. Hunter does not post the schematic for their fans. There is a common, low, medium, high and possibly the light and the reverse direction. IF you do manage to connect it, you will lose a lot of functionality.
Model 22450 does not have a reverse motor. The blades are spring loaded. You change the blade pitch by pushing in and twisting. This will change the air flow direction.
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
There is a problem. Check your wiring and your mechanical switch positions. Make sure the antenna is positioned as specified in the installation directions.
Look on the side of the Fan above the light fixture there is a little black switch you just need to switch it, make sure the fan is off before switching it.
I would pull it apart if necessary (depends on the model) and look for a small piece of packaging material in the air vents on the top of the motor. Good luck.
