YOU NEED A NEW BOOT ON THE INSIDE OF THE DOOR. WHEN YOU OPEN YOUR DOOR THERE SHOULD BE A GRAY RUBBERY RING. AS A MATTER OF FACT, IF YOU MOVE THAT RING AND PUT YOUR FINGERS IN IT YOU WILL PROBABLY FIND A MISSING SOCK OR TWO! THAT RING HAS TORN AND NEEDS TO BE REPLACED.
JB
I just ordered a replacement shipped for $96 from https://www.easyapplianceparts.com.
I had a trickle leak from the bottom of the door start in the last week. I cleaned the rubber gasket and cannot find evidence of any damage or holes but it still leaks. I was at a loss as to what to do and decided the seal must be worn out even though it appears fine.
Here is a video detailing the replacement process.
http://www.youtube.com/watch?v=EFDqUvBgxH4
What was the cost of this part? Same problem, but it looks like a $116 item . . .
