LG KU990 Viewty Logo
Posted on Aug 23, 2009
Viewty lite + charger, nothing else!
I have downloaded LG PC suite software for free, bought a usb data cable, and installed a 2Gb micro SD i have from my previous phone, took some snaps on holiday and now can't work out how to get the pictures onto my PC, the phone is set to mass storage, and i was expecting to plug it in and have it pop up like a usb storage drive, the phone seems to be doings it end properly, detecting the connection and going to mass storage mode, saying 'connected', but the PC doesnt seem to pick up the device and when i run the software and then the connection wizard, it fails to find the phone, is it just vista incompatibility or have i missed something?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
432
Points
5
Uninstall the LG PC suite and the plug the back in and openmy computer and it'll be in there.
1helpful
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
7helpful
2answers
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
Step One:
Step Two:
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
16helpful
3answers
How do I transfer pictures taken by my LG CF 360 phone to my PC?
The USB cable does not work apparently, UNLESS you have a micro SD card inserted. You also have to manually transfer the pictures from the phone's internal memory to the SD card first, then you can transfer them to the PC via the USB cable. The USB connector on the phone is one of the new USB micro A or micro B connectors - make sure you get the correct one. It looks like the one on the phone charger.
Nov 21, 2009 • Cell Phones
3helpful
2answers
Connection error to link phone to pc
hi 1st of all, reinstall the LG Pcsuite software, once that is done, you will see that a usb modem driver is also installed at the end of the process of installing the LG Pcsuite.
If you disconnect the usb cable from your mobile, then..
on your mobile go into the menu, then phone settings, then connectivity, there you will see USB connection mode.
If you click on USB connection mode you will see 3 options..
Data service, if selected tells your mobile to act as a modem when attached to your computer\
Mass Storage, if you select this option and then plug your usb cable back into your mobile, your computer will then discover your mobile phone as an external hard drive that will show up within Windows "My Computer", you are then able to browse your SD Micro memory card as an external hard drive and copy your files to your computer as simply as from one drive to another.
Remember if you want to use your phone again as a modem to go back to the USB connection mode menu and reselect Data Service.
Hope that helps
2helpful
3answers
Cannot copy anything to Memory card in LG Viewty
reformat your card through your pc. don't go for quick format. if it doesn't works after that also then get a software 4 low level formatting. if then also it doesn't works ask me again.
kindly rate my solution.
KU 990 PC Suite
if you have a micro sd car in your phone you can go into menu setings, phone settings, connectivity, usb connection mode, and chang it to data storage so your laptop finds your phone as a mass storage device (e.g. a usb)
My LG Viewty will not connect to my PC
make sure the phone is on data transfer (in phone settings - connectivity - usb connexion) if your using the lg suite.... plug the phone in first (to USB cable) then start the pc suite ,, if nothing... try using the connection wizard thing ,, it will search for connected phones.
17helpful
4answers
I NEED LG KU380 Pc Suite Driver
You don`t need any pc suit. You muse set your phone:
Enter in the phone to: menu->setting->connectivity->USB connection mode and here set Mass storage. Now put the usb cable and you can transfer data form memory card to your pc.
SanDisk 2GB micro SD memory stick isn't working in my laptop. I use a Sony Vaio with Vista, it has a digital camera memory stick slot, and pc adaptor slot for micro SDs. I slipped in my SanDisk memory...
Fixed it. All I needed to do was update the software drivers on my laptop. I have a sony vaio, so I looked up the software drivers they had online and downloaded them. After I installed them it worked flawlessly.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
