Electrical Supplies Logo
Kelly Jones Posted on Jul 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Honeywell hw4000 generator starts with spray wont stay running
Generator Guru Parts
Level 3:
Master:
  • Master 286 Answers
  • Posted on Aug 19, 2019
Master
Level 3:
Master:
Answers
286
Questions
Helped
148858
Points
1274
We are a Generator Parts Specialists. We have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
honeywell hw4000 generator starts with spray wont  - image-2fwsrbehqcya13uxwt41l5dc-2-0.jpg
Philip Morand
Level 2:
Sergeant:
  • Expert 205 Answers
  • Posted on Jul 12, 2019
Philip Morand
Expert
Level 2:
Sergeant:
Answers
205
Questions
Helped
82612
Points
549
Remove carburetor -disassemble to clean - reinstall to start generator. https://www.6ya.com/callphilipforhelp
5 Related Answers
Bill Johnson
  • 306 Answers
  • Posted on Jul 15, 2009
SOURCE: Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
Anonymous
  • 1206 Answers
  • Posted on Jan 26, 2010
SOURCE: car trys to turn over but wont start. when sprayed
check you fuel pressure seems like you can have a bad fuel pump in the tank.
seanpwright
Sean Wright
  • 2045 Answers
  • Posted on Feb 06, 2010
SOURCE: wont start. sprayed stater fluid but wont stay
Your carb needs cleaned out. Tke it off and clean it out well with a good carb cleaner and you should be fine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Anonymous
  • 8 Answers
  • Posted on Oct 29, 2012
SOURCE: husky generator 1850 watt wont stay running
does ithave fresh gas theres a chance there is water in the gas if thats not the case is the choke could be stuck on or the carb. is gummed up
A
Anonymous
  • Posted on Mar 26, 2015
SOURCE: Generator suddenly wont stay running
take all the load from it
start it does it run??
if it does then the gen is prob aok
your taking too much load when it starts
if this isnt the case
check for fuel flow and also air flow
other than this its an electrical system and detection problem
2answers
My honeywell Portable Generator Making A Loud Knocking Noise
Everything is repairable. First thing to do is a full strip down of the engine to see what has come loose. There are 280 models!
Google
make model, parts schematic
0060362 - Honeywell Generators
http://www.honeywellgenerators.com > product-info
Protect what matters most with the power of Honeywell Generators. ... Parts Manual / EV (Unit), PARTS MANUAL HW5500 49ST/CSA, 0J9776PMNL, EN.
Honeywell Generator Parts and Parts Diagrams
https://www.m-and-d.com > Honeywell_Generator_Parts
Matches 1 - 50 of 280 - Finding Honeywell Portable Generator Parts is simple with our online parts diagrams: 1. Click on the section of the machine for which ...
Honeywell Generator Parts & Spares
https://www.generatorguru.com > honeywell
Buy Honeywell Generator Parts now. Advice available from the leader in Portable Generator Parts. USA Canada UK EU AUS NZ.
Hw4000 generator wires are cut
If you need more support or need to purchase diesel generator set in the future, we recommend you a support website, you can search your answer on the website: www.dieselgeneratortech.com.
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
My Yokohma generator/welder will start, but will not stay running Why
It is most likely needing a deep cleaning of the carburetor. With the fuels we are now having to use the carburetor passages tends to clogged more easily when they sit unused.
I have a UST GG7500 Generator and it will not stay running.
Make sure there is enough oil, some generators wont start when oil level is low to protect from damage. Also have you cleaned the fuel injector, they get dirty and clogged just like a car.
6helpful
Generator will not run. Can start generator by spraying gas directly in to carburetor but will not idle/continue to run. Not currently connected to load. Trying to prepare for hurricane season. Can...
you have a blocked up card jet strip carb and clean out all jets
check fule flow from tank as well also clean all filters air + fule
best advice on missing hurricanes,,is move away?
2helpful
2answers
Wont start. sprayed stater fluid but wont stay running
6helpful
2answers
Wont stay running
the problems is in the carburetor, common problems when unit does not run often and rust get get build up. get some automotive carburetor cleaners and spray it heavy in the carb, don't worried about flooding it or damaging anything, it will dry out faster than gas. (use little gas if you need to) try to start it up and get it running with the carb cover off and continue to spray carb cleaner in the carb while the engine is running, do this couple of time and hope that would clear it out. if that don't work you will need to take it apart and clean it. you have small tiny object obstructing the carb flow. the unit doesn't have a fuel pump, it run on gravity feed, the carb are easily obstructed. hope that help a bit
1helpful
Top Honeywell Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Honeywell Electrical Supply Expert? Answer questions, earn points and help others
