Question about Canon CanoScan LiDE 90 Flatbed Scanner
Canon scanner lide90glass is broken where can i buy a replacement
Glass is broken where can i buy a replacement glass?
  • tbentulan Sep 03, 2009
    went to home depot and able to buy a clear glass .. it fits and scanner now works..
    Scholar:
  • 52 Answers
I suggest you to replace complete scanner instead of purchasing a glass, bcoz this will cost you more, and more over less possiblities that it will work.
Posted on Sep 03, 2009
6ya staff
SOURCE:
How to replace a broken scanner glass canon dr1210c
I don't know how the CANON DR 1210-C is assembled but I had an Artec and unscrewing it I could take off the glass.
Oct 12, 2014 | Canon DR-1210C Scanner
Glass scanner is broken
if it is within warranty period,then go to the manufacturer and get it repaired or replaced
Apr 02, 2012 | Canon Office Equipment & Supplies
Glass is broken. How do I replace the glass
HP does not sell the glass part for this scanner separately. Therefore replacing it yourself or having it repaired it not possible.
You will need to purchase a new scanner - the same one is available at www.dolphininc.net for $195.
Mar 05, 2011 | HP ScanJet 4600 Flatbed Scanner
The scanner glass is broken on my Cannon PIXMA MP460 - I want to have that replaced.. what would be cost
The Canon scanners are only one piece, you can only replace the entire scanner as no separate parts are available. The last one I replaced was $95.00 for the part.
Jan 09, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Light flashes and it says the scanner door is open but everything is closed
More common reasons are paper jam, dust/dirt, or a faulty sensor.
So, check for even the smallest pieces of paper, especially in the scanner area, use compresser air if necessary and clean the scanner glass.
Your sensor could also be broken/faulty. Not certain if the sensor is a user-replaceable part.
Hope this helps.
Aug 10, 2009 | Canon DR-2580C Path-Through Scanner
Canon IR 2016J Scanner does not move and glows while copying
Call service it may be lamp pcb or broken belt or ...
Apr 08, 2009 | Canon CLC 1140 Copier
Hi My Canoscan 9950f flatbed scanner glass has been smashed........ Is that the end of the road for it?? Or can it be fixed?
I had the same problem, shipping the scanner from Olympia, WA, to Austin, TX, the main glass broke (the sheet of glass you see when you open the scanner lid when it is set to scan an opaque object like an 8x10). I ordered a replacement part from the Canon parts center in New Jersey (732-521-7230) and at the time she told me there were only two left in the country, so you might be able to get the last one.
To replace it you just need to lift off the scanner cover, remove one scree in the bottom of each of the two wells the cover posts fit into, and lift the dark plastic part on the back of the scanner up (I think there are a couple of plastic snaps on the back side but they are not easily broken. Just pull up uniformly on both sides. Then you can remove the broken glass and put the new sheet in (align the plastic guides on the new sheet just like the ones on the old one were aligned).
Unfortunately, my scanner still doesn't work -- so I may have to give up on it. It seems stuck on a fairly well known failure code (2,178,0) when I start to scan and Canon customer support says there are no authorized service centers for the 9950F (I wonder if all their scanners are not repairable?).
Jan 04, 2009 | Canon CanoScan 9950F Flatbed Scanner
The glass for the scanner broke, i need another one
Eek, that's a tough call.
I think the cheapest would be to take the measurements and have a local glass company cut it to size.
I've never seen a manufacturer offer replacement glass tops for their scanners. The model isn't listed, but it's probably going to be cheaper to either buy a new one or buy a broken one off ebay and take the glass out of it to use in yours.
Dec 06, 2008 | HP Officejet 5510 All-In-One Thermal...
Broken glass
I would return it back to ebay. You can not just buy glass and the scanner will work. The scanner is put together in a vacum sealed room because if there is any debris on the glass or inside the glass it will produce black marks on the paper when you copy or send a fax. The unit may be ok to print from your pc but you will not be able to use the scanner glass at all.
Sep 17, 2007 | Brother 2440C Colour Plain Paper Inkjet...
Canon CanoScan LiDE 90 Flatbed Scanner Logo
219 people viewed this question
Clive
Clive
old marine
old marine
Ekse
