I can add the music files to the slides, but they won't play.
Hi ,I' d like strongly recommend a software to you Leawo PowerPoint to DVD Pro , although there are already many answers here. This software just perfectly solve the problem on how to add background music on PPT. All you need to do is to import your source ppt file into the program and add the music to your file. As an all-inclusive software, it can also convert your ppt to all kinds of videos and even Blu-ray discs. If you want know more features, you can download the free trail on its website:http://www.leawo.org/powerpoint-to-dvd-pro/
Feel free to try Leawo PowerPoint to DVD Pro
You can play your presentation video on most video players, share on video sharing sites like YouTube and Hulu, and distribute on portable devices like iPod, iPhone and iPad. Convert PowerPoint To Video
http://www.powerpoint-video-converter.com/
Hi, which version of PowerPoint do you use? Take PowerPoint 2003 for example. PowerPoint 2007 is similar with it. Here are the steps:
1. Open PowerPoint and display the slide where you want the music to begin. On the Insert menu, point to Movies and Sounds, and then click Sound from File. Locate the folder that contains the sound file and then double-click the file you want.
2. When a message is displayed, click to play the music or sound automatically.
Tips:
Free and easy method:
Use PPT to Flash to add music to PowerPoint with one click. Use this free trial one, you also can insert Flash for free. It will save a lot of time for your daily work.
To view more solution about music in PowerPoint, please refer to:
http://blogs.digitalmediaonlineinc.com/ppt/entry/20080908
Hope these hope.
Does the music file play when you click on it? (Drag the sound icon someplace visible on your slide and preview it.)
If it does play when you click on it, you just need to animate the music. The sound file has to be a part of your slide animation--that's what tells it when to start/stop playing. When you insert a sound file, PPT may ask you whether you want it to start automatically or wait to be clicked.
Or, you can right-click an existing sound file and go CUSTOM ANIMATION. Depending on your version of PPT, what happens next will be different. But you should be able to set the sound file to play when the slide displays without being clicked.
The PowerPoint software program allows you to create slide presentations that can be viewed on any computer.
While some graphic artists specialize in developing compelling presentations, anyone can develop a PowerPoint slide presentation that is attractive and readable.
Follow these steps to develop your own slide show.
Open your PowerPoint program. When the dialog box opens, click on the "Blank Presentation" option.
Choose an "AutoLayout" format.
Begin with the title slide layout, which is the first one on the left. Click "OK," and you will have a title slide to work with.
Add text to your slide by clicking in the title text box and typing a title.
Do the same thing in the subtitle box.
Create another slide by clicking the "New Slide" button on the Common Tasks toolbar.
When the AutoLayout dialog box appears, choose a layout for this slide.
Keep adding new slides until your presentation is complete.
Move from slide to slide by clicking the button on the lower-right corner of the PowerPoint window.
Clicking the button with the upward-pointing arrows will take you to the previous slide, and clicking the button with the downward-pointing arrows will take you to the next slide.
Save your presentation. Click the "File" menu and then click "Save As."
A dialog box will appear, and you'll be able to type in a name for your presentation.
The presentation will be saved to your hard drive.
as for the kreb cycle disgram im not sure
hope this helps
Find links to information about saving presentations in the See Also section.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
I have made several powerpoints with music (actual songs) before, but now am unable to. I can add the song, but it won't play in the presentation.
What if the sound file doens't play when you click on it, but there is nothing wrong with the sound file (it plays in music players)?
