I need to print on bypasstray
SOURCE: code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
SOURCE: Minolta EP 2050 CS Pro
This machine has been discontinued for some time now. Not sure exactly how long but I haven't seen one in the field for a while. try taking a manilla folder a manually feeding it through the same direction as the paper goes through the machine afterr pulling out the paper tray all the way to see if you dislodge any paper. Other than self remedies, it isn't worth the money for a service call.
SOURCE: i have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
SOURCE: power is on, but blades dont move
What do mean about blades not moving. The machine is a legacy minolta machine. The paper draw rollers mite need replacement. does the paper leave the draw?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
