Question about Toshiba Portege M400 PPM40U01000E Tablet PC
Toshiba Portege Tablet running Vista, locks up and fan runs noisy
I didn't have this problem with an older version of Windows. It happens EVERY time I try to use it on battery power, within 10-20 seconds from start-up. If I keep it plugged in, I can usually avoid it, except sometimes when it should be going to "sleep". The only way to stop the noisy, fast, hot fan is to flip the power switch to reboot.
It drives me crazy to have a laptop that I can't use without the power cord plugged in!
6ya staff
SOURCE:
AvioriX
ExpressFiX
  • 689 Answers
SOURCE: Portege 3500
Hi
You can obtain the Recovery disk from Toshiba. Toshiba hotline number 1-800-457-7777 (US) 0844 800 6020 (UK). You need to provide your computer's part number correct to get the matching recovery disk. Usually they charges $39.95 including shipping to your address in US. Alternately you can go to http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/generic_content.jsp?service=UK&ID=Support_Homepage_uk
Good Luck
Posted on Dec 29, 2007
Anonymous
  • 148 Answers
SOURCE: Soundcard driver for Toshiba Tecra M4-PTM40A Tablet.
The XP SP2 driver should work. http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=980401&moid=893054&rpn=PTM42U&BV_SessionID=@@@@0801357951.1210987874@@@@&BV_EngineID=ccceadeedmeimgicgfkceghdgngdgmn.0&ct=DL&all_docs=false
Posted on May 17, 2008
Anonymous
  • 4 Answers
SOURCE: toshiba M400 tablet wont start
I think it might be the systemboard here.. but I strongly don't advise taking it apart yourself unless you know how because it can be tricky and you must be grounded
Posted on Sep 24, 2008
Bfsas1
Brett McGuigan
  • 258 Answers
SOURCE: Recovery CD
ok you wouldn't have been supplied a recovery cd, you have to create it, to create one have 2 blank dvd discs ready and go to start menu and select help type in a search for recovery cd, this will explain how to create one....if your computer won't load into windows you will have to re-install windows again, cheers, any other probs please get back to me.
Brett.
Posted on Dec 30, 2008
anjana03
Roshan Rijal
  • 361 Answers
SOURCE: Touch Screen not working or Pen?
in my opinon. you should be re instal this touch pad driver.
Posted on Jun 13, 2009
Hi I have a toshiba portege m750 and my little brother was using it and I have decided to use it for college but the only thing is he cannot remember I was just wondering how would I go about changing the...
You can set a user password from inside Windows. From the configuration panel look for an icon that represents two persons and click on it. Follow instructions on setting a user password.
You can also set a password on boot but you have to be careful: If you forget it you cannot open the tablet to remove the password. You will need to take the computer to a Toshiba Certified Service Center.
To set the password on boot you can use the BIOS SetUp configuration or a Toshiba Windows applications (HRWset).
For Windows XP tablet PC edition 2005
If you have the CrossMenu application you can run the HRWsetup from there. You can also go to All programs, Toshiba Utilities and look for HRWSetUp.
For Windows Vista or Windows 7, the name of the application may be Toshiba Security Assist.
Be very careful. You must not lose the password
Jul 30, 2011 | Toshiba Portege M700-S7002 Tablet PC
I have install win 7 on portege m400 , but pen not working! Please help me!
Go to the Toshiba Mobile support web site for you exact model. Select Drivers download. Select Windows 7 32bits or 64 bit and download the latest versions of all that relate to the Tablet module, and that includes the Wacom driver.
If you Windows is genuine you can uninstall all the Wacom drivers then execute the Check new hardware wizard ( of Hardware changes) or even Windows Update
Jul 06, 2011 | Toshiba Portege M400 PPM40U01000E Tablet...
I have a Toshiba Portege M400. It runs ok if I leave it on a flat surface. However, if I try to move it the screen freezes up and the fan starts running very loudly. I am unable to do anything except cut...
Sounds like there might be dust inside of the laptop that is blocking one of the air vents. Plus the connectors to the screen may need to be reseated so that way the screen can be moved freely without it locking up on you and cutting off.
You have two issues going on. Bring it to somebody so they can open it up and make sure the air vents are cleaned out. Also they need to make sure the CPU fan is running properly. Then with the screen the connectors need to be reseated. Its also quite possible the screen connector might need to be replaced.
If the laptop is under warranty see if Toshiba will reapir it.
May 27, 2011 | Toshiba Portege M400 PPM40U01000E Tablet...
My laptop "toshiba tablet portage
If your computer is still under warranty you can contact the Toshiba support site and order recovery media. They will refer you to the company that sells them. The cost is about 45 dollars + taxes.
Even if your computer is no longer under warranty you may still be able to obtain the recovery medias.
Failing that, you may consider buying a retail version of the Windows Operating system and install it on the computer. Some custom buttons may not work, and you will have to go to the Toshiba support web site to download the drivers for your computer. Before buying a version of Windows, check the Toshiba site for your computer and your intented OS (WinXP 32/64, Vista 32/64, or Win 7 32/64) )to see if they have drivers.
May 20, 2011 | Toshiba Portege 3500 Tablet PC
I need a touch screen driver ot toshiba portege 3500 tablet laptop pc
You can download any orall the Windows XP or Vista device drivers for your model laptop from theToshiba WEB site from their download page. Make sure you enter the model ofyour laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Mar 30, 2011 | Toshiba Portege 3500 Tablet PC
My Portege 3500 cannot connect via it's WIFI, should I change the WIFI driver? And also can I get Ethernet driver for my Portege 3500?
You can download any/allthe Windows XP or Vista device drivers for your model laptop from the ToshibaWEB site from their download page. Make sure you enter the model of your laptopso you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Dec 23, 2010 | Toshiba Portege 3500 Tablet PC
I cant use the pen or even touch with my fing. iam using windos 7
hi
the screen on the portege m200 needs the wacom pen and tablet driver
just go to wacon.com
the specific driver you need is this on
Driver 5.05-7 for Windows Vista (32 and 64 bit), XP
Sep 17, 2010 | Toshiba Portege M200 Tablet PC
Audio driver toshiba portege 3500
Go to the Toshiba website and download the updated drivers for your system. They are free.
Oct 14, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba portege 3500 tablet pc
You should contact Toshiba service and order a recovery CD for that model. You can also install any Windows XP version, but it will not provide support for the tablet functionalities, which means that you will have a notebook that is not a tablet.
Note: Actually the original operating system is Windows XP Tablet PC Edition 2005: It is Win XP Pro + Tablet PC software.
I have heard that Vista provides support for Tablet functionalities, but you may still have to buy it from Toshiba because of the drivers for the specific hardware.
I installed Linux Ubuntu on a tablet. The latest version of Ubuntu provides some support for the wacom stylus pen, but not much else.
Hope it gives you some leads to follow through.
Aug 27, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba Portege M400 PPM40U01000E Tablet PC Logo
275 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Ekse
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
