My microphone dosnt work on my laptop and i have vista i click on playback devices and the micrphone dosnt pick any sound up i plugged it in on another computer and it works its a Creative fatal1ty headset if that helps
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
I am using Vista 32-bit, Logitech Clear Chat Style
Hope can help
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices
Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure
that there is not a check-mark in the MUTE box against microphone in the list
of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't
checked before closing the window.
Now click the VOLUME button in the
SOUND RECORDING BOX. Here SELECT microphone as an input source for recording
(as opposed to un-checking mute in the playback controls).
NOTE if your microphone
is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES
on the tool-bar and place a check against microphone in the list
entitled 'show the following volume controls' and then click OK. Same
applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume
as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust
slider to suit.
You might put a check mark in the box
to show the volume control on the Task Bar so you can go straight to it to make
adjustments in the future.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
You may need to enable the microphone in control panel - see below
You will also need to check the correct sound source is selected in your recording program.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
If you still don't get enough volume then you may need a pre-amplifier to boost the signal
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
