SOURCE: Can't figure out how to change watch strap
Hi, try this - it worked for me. Use a needle to poke the ends of the watch strap axel (at the end and running across the strap). This should then allow you to lit the silver panels at the top and bottom of the watch face off. The axel should then slide out. I did this by pushing one end of it through with a needle so that the other end poked out enough to pull it out with a paid of pliers.
SOURCE: Broken wrist band
The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
SOURCE: i have a sector 600 series with a black rubber
Here you will find Sector contact details:
http://www.sectornolimits.eu/#/eng/contact
And here is the link where you can find nearest Sector:
http://www.watchservicecenter.it/
You have to contact them and ask for the strap/bracelet you are after.
Rate me, please.
SOURCE: require a replacement band for casio triple sensor
Yes, go to "www.casiowatches.shriro.com.au/" where you should be able to find the information you need.
Click on "service agents" to find the address of your nearest agent.
