Televison & Video Logo
Anonymous Posted on Aug 24, 2009
Darkened picture in perfect border around main
Darkened picture in border around main picture.
border approx. 3-4 inchest inward with yellowish color. Any ideas?
Other than that - picture is nice and bright.
thanks!
Vern
Anonymous
Level 2:
  • Expert 113 Answers
  • Posted on Aug 24, 2009
Anonymous
Expert
Level 2:
Answers
113
Questions
0
Helped
30873
Points
338
CHECK TO SEE IF YOU HAV THE TEX ON IN THE MEAU IF SO TURN IT OFF
Uneven borders how do i fix it
If you are trying to do this by setting borders manually you are probably running into the Canon's minefield of "minimal printed borders" which throw off calculations. The manual setting is primarily for off-setting images rather than for perfectly centered images.
For a centered image, the borders are automatically set by the relationship of image sizing to paper size, with "center image" checked and other sizing options unchecked. This has worked perfectly in the three Canon printers I've owned, whereas trying to set even borders manually was always off a bit and a real pain.
If you want the same border width for all sides, the aspect ratio of the paper and image will have to be different, strangely enough, for all but square images. For 1" borders all around on 10x15 paper, e.g., your 2:3 AR image will have to be cropped and sized to 8X13" dimensions.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
3answers
It maybe a filter problem go through the steps you took when installing the new bulb and check all then test.
Thanks J
I have a JVC 48' widescreen tv approx. 7 - 8 yrs old. the picture is now extremely bad all of the colors seem to be out of wack and the picture bows inward toward the middle at the top and bows inward...
There's a miror or one like this might have a ''aluminium sheet'' miror.
Open the upper back cover to see what going on there, pretty sure something run out of place...
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
2answers
InFocus LP70 color problem
try resetting the settings to factory default through the menu. if there's still a problem, take the cover off. if you look from the back of the machine, inside on the bottom left, you'll see the main board attached by a large white plug. use something thin and non-metalic to push the bottom of the board towards the plug to tighten it. now do the same to the other side of the plug. this should solve it. if it doesn't, you need to replace the main board.
Yellow colored screen
This is a problem with the CRTs(picture tubes) or the coolant chamber(s) of same. The cost to replace the affected parts with be quite high. Expect to spend $400-600 to replace the CRT(s)
michtech
Screen border
You are probably in the "3:2" ratio print setting. This is accessed through the "F" button, under image quality. The 3:2 is a ratio of height to width which corresponds to a 4x6 inch print. The other settings are approx. 4x5.33 inches in h to w ratio. Just change the quality setting to the larger megapixel settings and the bars will disappear.
Picture problem
I had the same exact same problem. You can get a repair kit from this site. http:///www.magnavoxhelp.com
Wavy colors do not line up
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.eserviceinfo.com/
1helpful
2answers
DARK HORIZON AREA AT TOP OF SCREEN
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
