Electrical Supplies Logo
Posted on Aug 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New Skygo '' Lifan'' 1800 generator, runs fine, produces no power.
  • Sheldon Dedek May 11, 2010
    Has it ever worked correctly? I know that you stated that it is new, but was it having this problem out of the box?
sal sabea
Level 2:
  • Expert 98 Answers
  • Posted on Oct 16, 2009
sal sabea
Expert
Level 2:
Answers
98
Questions
0
Helped
50482
Points
203
You should check wireing then brushes..
finally check AVR
don't hesitate to write to me for further information:
[email protected]
Hi all my 1800w generator starts fine never a problem my problem out doesn't produce power sorry it producers enoughter power to run my DVD and nothing else I live on my brother's farm away from the main...
Hi!
If you have a portable Generator then we can help. :)
Check out our testing videos and see how to pinpoint the problem.
https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
If you need more advice we can get you in contact with one of our Generator Engineers to guide you. We do not charge for this service and are happy to assist you throughout the repair.
https://www.generatorguru.com/need-help/
Kind regards
The Generator Guru Team
Specialist Portable Generator Engineers & Parts Worldwide
ww
w.GeneratorGuru.com
Have a lifan 2200 energy storm generator and shuts off all the time
Change the oil, or remove the lead to the oil pressure sensor switch
5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Lifan skygo sg125t-6, when running it is loosing power when it gets to a hill drastically, it wont go over 20mph when at full throttle, on the flat it runs ok. is this the timing ? ive checked the piston...
You have a four stroke engine and it needs a valve job.
Have the dealer do a compression check to confirm the need for a valve job.
If you see white smoke coming from the exhaust while riding, then you may want to bore the cylinder and add new piston and rings. It is less money to do the piston along with the valves as opposed to doing them separately. Also, you will have even better compression and performance.
Please rate this solution as a " FixYa " Thanks!
Engine runs but won't generate any electricity
Sometimes the generator loses the magnetic field that allows it to produce power. Do a Google search on "flashing a generator field". There are many ways to do it, but I would recommend doing some reading before trying it. Your "dead" generator could produce hazardous voltage once it comes back to life.
Also, before trying any of this, make sure the circuit breakers on the generator (if equipped) are not tripped.
Good luck and be careful!
4helpful
Honda generator em 1800
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
