Sometimes flash memory can be exhausted, so to speak, and will stop functioning. This is all you can do to get your pictures back. After that try running a format and then the error check tools under the tools tab in the right click properties window.
Download a program called
FreeUndelete from
here and install it but before you open it, connect your MP3 player or insert your SD card. After you start the program up, select the drive letter that represents the memory you want to scan for deleted files.Click the scan button above the list and wait. If there's too many results, then look near the bottom of the window. There should be a"Filter found files" line where you can enter in the file type of the photos you lost. It probably should be this: "*.jpg" Once you have found the files you want to recover, create a folder you want to save them to in your My Documents folder and copy the path to that folder by right clicking on it then clicking properties. The path you need to copy is the line called Location (don't actually copy "Location: ".Just what's after it :p ) Now paste it in the line called "Undelete selected file(s) To" under the "Filter found files" line. Make sure you paste over the existing text. Finally, click the
Undelete button to the right and Viola! check the files out in the folder you created in your My Documents folder.
