1400H is here and close enough.
https://www.google.com/search?q=NewAir+acp-1600h+manual
SOURCE: Not blowing cool air
Likely needs freon has leak needs repair local hvac contractor can help. T
SOURCE: My NewAir ACP-1000E Portable Air Conditioner says
Check the float thaat is the sensor to indicate the water level to the micro controller. The wires are cut or the float is deffective .
Check and replace.Credit if helpful with this tip.
SOURCE: My NewAir ACP-1400/H air conditioner freezes up. I
Its sounds like a refrigerant leak from the factory if you just got it. Check your warranty and call the manufacturer for repairs. Unfortunately there is no simple fix.
