HP PL4245N 42 in. HD-Ready Plasma Television Logo
Posted on Aug 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magnavox 42" tv has no picture, but still has sound
My 42" plasma tv just went completly blank and still has sound? The manuel said it could be in "protective mode"? Is there a reset button or sould I call it quits?
Anonymous
Level 2:
  • Expert 113 Answers
  • Posted on Aug 24, 2009
Anonymous
Expert
Level 2:
Answers
113
Questions
0
Helped
30868
Points
338
YOU MAY HAVE BAD Z SUS BOARD
Justin Smith
Level 2:
Scholar:
  • Expert 135 Answers
Justin Smith
Expert
Level 2:
Scholar:
Answers
135
Questions
Helped
33412
Points
229
Hi there! Sounds like the Y-Sustain and/or Z-Sustain boards. This should be written on the boards. Check the fuses on these boards and if found to be blown try replacing with the same rating fuse and see what happens. If not successful then the boards will have to be replaced. You may have to also replace the control board if these come in a kit and not loose. Also check the voltages to these boards. The Power Supply also have a role to play in all this. Please beware of High Current!!! Best Wishes and Good Luck, JUS004
I HAVE 42 INCH MAGNAVOX PLASMA TV AND THE SOUND WORKS BUT THE TV DOES NOT SHOW A PICTURE AT ALL IT IS JUST ALL BLACK,COULD IT BE THE PICTURE TUBE THAT WENT OUT.
yes...the video card could have gone out but most likely you have a connection that is loose or bad. I would check those first. If you have done so then I would try another video port and verify that it is the screen that is out and not just the port you are in.
My 42 in. 42HP66 Toshiba Plasma TV popped and screen went blank
One of your y driver almost go bad. For your future problem please visit my site athttp://billy-tech.blogspot.com/
Lost picture on my LG 42" plasma model number 42PC1DV
it is problem high voltage unite problem (EHT) change it then solve your problem
42 inch DO42746 no picture or sound
It is still possible the z sustain board is bad. or an x driver board.
No picture just went blank still have sound??
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem..
rate me
Screen has gone blank. Is this common? Fixable?
Contact us to join our group who is taking action for the same issue. [email protected]
42" magnavox plasma started to smoke, has audio but no video?
power board replacement a burnt circuit is visible upon opening unit and removing the power board.
1helpful
My TV JVC Flat screen has no picture but does give sound
my 42" Emerson Plasma tv went blank. I can't see any picture but i do hear the sound?
2helpful
4answers
Magnavox Plasma HDTV Red light
I had a similar problem with my magnavox tv with the blinking light issue. Eventually it just didn't come one anymore. Looking at other forms they said the problem was a bad capacitor number 2074 located on the power supply board. When I opened my tv, I noticed that the capacitor was bulging and burnt up. I bought a new one labeled 2200uf 35v and did some solder to attach the new piece. Put the tv back together and it works like new. No more blinking light. I hope this helps.
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
