Question about Uniden Radio Communications
How to adjust the hissing and squelch sound on my uniden bc150 scanner.
Anonymous
SOURCE:
Anonymous
SOURCE: police scanner
Uniden wont admit it but it has installed faulty squelch on the 248's I had the same issue. Wont sell parts either. 60 bucks to fix.
Posted on Aug 27, 2008
Anonymous
SOURCE: NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Posted on Aug 28, 2008
Communicomm
David Eisenberg
  • 90 Answers
SOURCE: Unable to quit the squelch
This is an internal problem that can only be repaired by a technician familiar with Bearcat scanners. If you live near NJ, call 973-831-5900.
Posted on Jan 05, 2009
stevedavis4
  • 16 Answers
SOURCE: Uniden UBC72XLT scanner problem.
The cheapest solution would be to directly program the frequencies that are available in your area, usually this is public information with the exception of high security channels, you can call each location and ask them what frequency they broadcast
Posted on Jun 07, 2009
Jack Chambers
  • 99 Answers
SOURCE: can't break squelch ? Have Uniden Bearcat hand held scanning radi
Look at the squelch knob. If it is turned fully counterclockwise, it is in "Auto". Turn the knob clockwise to enter the manual mode and adjust the range untill static is heard. Reverse direction until the static is no longer heard.
Posted on Aug 31, 2010
What did you mean by change the squelch?
The squelch control gets rid of the hissing on a blank channel. Finda blank channel, turn up the squelch control until the hissing stops. The scanner should then scan the channels and stop on a busy one.
Jul 12, 2014 | Uniden Bearcat Scanner Bc355c 800 Mhz...
I have a bc60xlt andno matter how i turn the squelch i get the same hiss what happened
The Bearcat Scanner is neat hand held scanner, Is the scanner programed? Depress the WX for weather and see if the weather channel is available. The squelch knob should be turned clockwise and the noise level should decrease (actually you are decreasing the allowable signals to be received). If you get no response from a know frequency, then the squelch pot may need cleaning or replacement may be in order.....Cost for repair at service shop may not be feasible.
May 26, 2014 | Uniden BC60XLT Handheld Scanner
Can't break squelch ? Have Uniden Bearcat hand held scanning radi
Jul 17, 2010 | Uniden BC248CLT Base Scanner
Hi um i have this scanner and the frequencie come in but it comes in and out like the antana dosint work
Adjust the squelch until you hear a hissing sound, and trun the knob back slowly until the hissing stops.
Jun 12, 2010 | Uniden BC60XLT-1 Handheld Scanner
Static
Check your SQUELCH setting - that will make the 'hiss' sound if it is turned too far or bumped.
May 27, 2010 | Uniden BC246T Handheld Scanner
New BC355C put 7 channels in,but only will stop on 2
1. Be sure sure that your squelch is adjusted properly. While scanning, turn the SQUELCH control down slowly until scanning stops and you hear a hissing sound. Then slowly turn the control back up until scanning resumes. That will set a proper threshold level for the frequencies you're monitoring.
2. Be sure that signals are not blocked in your area. Topography plays a large part in VHF and UHF radio reception. A hill, a tall building, even a thick grove of trees can prevent a signal from reaching your antenna.
3. It's possible that there was just no traffic on the five freqs while you were listening.
4. Be sure that the frequencies you've programmed are assigned in your area.
5. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
BillB
Jan 26, 2010 | Uniden BC350C Base Scanner
I don't have the manual for my Uniden Bearcat BC 855 scanner.
You can download/print the complete manual for your scanner by following the link below. It's a free download, and it provides detailed programming instructions. If you're programming a channel that is "empty" (showing 000.0000) just enter your frequency. Empty channels automatically show LOCKOUT but it clears with programming. The squelch setting will vary according to the strength of the signals you receive. Once you start scanning, turn the squelch down until scanning stops and you hear a hissing sound, then turn the control up slowly until scanning resumes.
Dec 30, 2009 | Uniden BC248CLT Base Scanner
Makes a squlesh sound like a CB radio when monitoring radio or transmitting
GMRS transceivers, yes - like CB radios, have squelch or threshold tuning circuitry. Without it you would be listening to an irritating hissing noise between transmissions, and the radios would not be able to scan. The big difference is that the squelch setting on a CB is adjustable, but it's automatic on GMRS sets.
Dec 24, 2009 | Uniden GMR1838-2CK Two Way Radio
How do i adjust the squlech on my unidenbc12xlt hand held scanner
The actual setting will vary according to the strength of the signals you're receiving, so it may require adjustment as you move around. With the unit scanning, turn the squelch down slowly until scanning stops and you hear a hissing noise. They slowly bring the level up until scanning resumes.
Oct 29, 2009 | Uniden BC72XLT Handheld Scanner
CB92XLT hand held scanner keeps hissing and won't scan
Got the same issue man, you fix it? im checking mine over now, will let you know if i fix it. if you still need it.
Feb 14, 2009 | Uniden BC92XLT Handheld Scanner
Radio Communications Logo
89 people viewed this question
Top Uniden Radio Communications Experts
Jason
Robert McClure
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
