I unplugged it, reset the plug, the EP light went off, read 32 then. After about a minute, it went back to EP again. Called a repairman. I bought it 3 days ago.
That is the Error code or Fault code. If you going to DIY, firstly, please check wire connection feeds mechanical system
EP is an error code resulting from a failed sensor on the cold side. Check the sensor that hangs or is mounted to the from of condenser if this sensor has failed or is unplugged the unit will not run and error code EP will show..
SOURCE: haier air conditioner
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=1797 Hope this helps! ;)
SOURCE: EP Message - no cool air on a GE Air Conditioner
I just posted this on another one, but try unplugging it and pushing the reset buttons on the side of the plug. It worked to fix mine so far...
SOURCE: carrier spit type air conditioner 5 blinks
Unit should reset with circuit breaker off/wait/on. Codes are near the end of this manual.
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/48ss,sx-12si.pdf
My panel cannot be read.
