Scanner error code 6 has appeared, how do I fix the problem?
You can try this fix.
-switch off the printer, then remove all cables connecting to the printer but just the power cable.
-then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
-continue holding the button till you see "perment storage init" displayed and releas the button.
-then at a given point of time the printer will ask you to change laguage,time,date etc.
If this does not sort the issue service is required.
if this does not sort the issue service is required.
I have already tried that and it hasn't helped.
