Maxent MX-50X3 50 in. HD-Ready Plasma Television Logo
Posted on Dec 04, 2007
Maxent MX50X3 HDMI input
I have two problems with my Maxent MX 50X3. One is when my Comcast HD Cable box is plugged up using the Component video cables i get, what my cable tech calls, hum bars. I don't know what to do to get rid of this problem. The only thing that worked, for some reason, is using the HDMI input. When using the HDMI the picture was excellent. This brings up problem two. I came home one day and the HDMI input doesn't work at all. I just get a blue screen. I tried plugging my Samsung DVD player up, thinking it may be the cable, but the problem remains. Now I'm stuck using the component video with the hum bar problem. Also my 360 uses component video and has no hum bar problems. Can someone help me please?
  • 4 more comments
  • Arnbo Mar 16, 2008
    I have the same problem. Blue screen when using HDMI. I tried new cables but it didnt help.
  • Bugnartie Oct 22, 2008
    I have the MX-50x3 moniter and everything was working just fine with the HDMI cable iinput, that is until I had to unplug all of the connections from the back of the moniter to move it. Now the moniter doesn't pick up the HDMI signal. The upper right hand corner of the moniter states "no support" when HDMI is selected. Everything is plugged back in to the exact locations they were in just 5 min's ago. Is there something wrong with the moniter or what?
  • Anonymous Dec 18, 2008
    Same problem here. One day I turned the TV on and selected HDMI, and it just had a blue screen. All other inputs are just fine, This is beginnning to sound like a common thing.
  • Anonymous Jan 31, 2009
    Same prob. here,,wedged folded paper to tweek the plug & it worked again for a while, but became a pain in the @@@, gonna go in & check the connection at the back of the plug, cant be that hard to replace the plug...?
  • Anonymous Feb 07, 2009
    A few of my friends and I have this same TV...none of our hdmi ports work
  • soccermanbg Feb 16, 2009
    same problem. I have a playstation 3 for use with HDMI and getting fustrated trying to wonder why it doesnt work. What a waste of time. I bought it nearly 2 1/2 years ago(and now assuming that it was a marketing trick) as promoting the product as a future wave of technology with its ONE HDMI port. Didnt care about HDMI back then, and NOW I DO>
A
Anonymous
I had the same problem and found that the ground wire outside where the cable companys box is was not even hooked up. It was just hanging there, once I hooked it up it went away. The cable company gave me the run around telling me it wasn't their fault. I now have Direct Tv.
How do I connect the coax antenna cable?
This unit doesn't have a tuner, This is what I found when researching this question for you.Maybe you can hookup DVD player or VCR player with audio and video cables, I know some VCR's have HDMI on them too that can be hooked on that TV. Good Luck
I have a 42 inch maxent but i dont know where to plug my cable cord because i have a comcast box and theres no where in the t.v to plug my cable cord
If your comcast box has video (yellow), audio R (Red), audio L (White) out, just connect RC cables to the input of the TV at video, audio-in RC Jacks. If your comcast box has only RF out, buy one RF to audio-video converter and then connect these to the TV.
HDMI input blown, no HDMI image..
we have to unplug the hdmi cord at the cable box and plug back in . Try it, I just figured my set is on it's last leg
I am having problems programing my Maxent MX50X3 TV to our Direct TV system.
Hi, Your Direct TV system runs on channel 3 or 4 on the Maxent HDTV and the decoder box(PVR) works all the channels. So you might not be able to program your HDTV. Good luck.
How do I hook up my maxent tv to cable
use 1 of these 4 options
On the back of the cable box there should be outputs
Coaxial ( regular cable wire that screws on)
RCA plugs (yellow red & white )
Component plugs ( green, red, blue for video) (red, white for audio)
HDMI ( on HD cable box only)
After connecting make sure your tv is on the input you connected on the back of the TV
2helpful
2answers
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
My antenna has a coax-my 50 in Maxent mx50X3 has no coax hook up. How do I connect these two?
That unit does not have a tuner so it does not have an antenna input. You need to connect a cable box, satellite box, VCR with a digital tuner (or an additional DTV box for converted input), or DVR to one of the HDMI, S-Video, or Component inputs to view TV.
Maxent MX-50X3 50 in. HDTV-Ready Plasma
Yes I had this problem. Unplug the power cord for 1 min then plug it back in. The tv will reset and the buttons then work again.
Top Maxent Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
