SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
SOURCE: LG 42LC2D Hooking up surround sound
are you going through a cable box ? if so, then just connect the video out cable from the surround system to the video in on the side of the LG. Then connect the left & right audio in cables into the cable box coming out of the sound system, this will work, I just set mine up this way, any other issues let me know.If you are not using a cable box then simple connect out of the sound system the left & right audio out cables AND the video cable into the side of the LG ( the left side is where these in puts are).
SOURCE: panasonic home theater
switch the HDMI cable to another HDMI port (if available).
or use and AVI/COMPONENT to make sure the device (HOME THEATHER) is working fine.
Try also another HDMI cable or hook another device into it to see how it works.
If you determine the HDMI port in not working properly, then your Mainboard is damaged and need to be replaced, try EBAY for a general
picture of prices but you will need your product code wich is located
in the back of the TV next to serial number.
SOURCE: i have just bought an acer aspire 7720g laptop and
Hi
please see the link below it is very detailed (i could have copied and pasted it and made it my own but that wouldnt be right), the video is also very good
http://www.geekwithlaptop.com/how-to-connect-laptop-to-tv
Please leave feedback/vote if my answer was helpful
SOURCE: LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
