IF THE IS A SOFTWARE OR PDF OR ANY MEANS TO GET HELP PLIS SHARE
Go into your Control Panel and you'll find something called Region & Language. Follow what it says on the screen. The first thing they show you is Format: that's where you can change it. Follow all the screen to be sure not to leave anything out. And you might have to restart your pc. It will tell you when your done. Don't worry, it's easy. If i can do it you can. Good luck
Lynn
SOURCE: Japanese to English Version
I am not sure if this will help or not but it is worth a try. Here is how to change the language. Hopefully there will be a option to choose English.
How to change the language:
Note: Some games that feature multiple languages may display in the language you have selected in the system settings.
English.
SOURCE: Sony cybershot dsc w320. A
Press the Menu button, the one the top left of the control panel. Look for an icon shaped like a tool box, and press the central button on the control panel. Select the category that has an icon that looks like a hammer, that's the Main Settings. The second option there is the Language Settings, press the central button on it to get a list of available languages, English should be there, just get over it, and press de Central Button again and there you are.
SOURCE: toyota estima language settings
my toyoto estma language japan how to chang english language
