I can not send SMS message. I get an error "Your text message can not be sent. Be certain that your service center address is correct in Settings and then try sending the message again." How will I check and set my SMS message center number? Please help me...
I had the same problem and came to this site for help but the solutions didn't solve the problem of "cannot send text message" on htc touch hd. All service numbers correct. Went to START/SETTINGS/CONNECTIONS/ADVANCED NETWORK/SMS SERVICE then changed from "gprs" to "gprs preferred". Double checked and had reverted to "GSM" but sms now works - finally!!! Hope this helps.
You can do this at Settings -> Personal -> Phone -> Services -> Voice Mail and Text Messages -> Get Settings button
Go to settings>personal>phone>band change network type to GSM and Select GSM/UMTS band to UMTS(900+2100)+GSM(900+1800). Hope this solves everyone's problem of text message sending/receiving problem.
I tried what saibrains said, but it says 'cannot read settings from the network. try viewing later, or disconnect data connection and try again.'
it always says so... though i hadn't connected data connection.
I changed settings of my HTC Touch Diamond from GSM to GSM preferred (as daviddavi479 said) and it is now working fine. I didn't feel the need to change back to GSM as it is working fine with GSM preferred. Thanks everyone for your help.
Hey all i have htc touch diamond 2 i cant send sms with this phone but if i insert my sim card in another phone i can send sms easily i hav problem only with HTC toch diamond 2 when i want send sms can any body help u(i check message center numwas correct )
Hi... I have a htc touch hd mobile.. problem is the message send failed.. The network which I use is Ufone and the Message Center Number is correct but still its not sending the message I dont know is there any manual setting required in phone or some network setting required... Please help me if any body knows about my problem... Thankkssss
Plz guide again i cannot send the message
I was very Upset from Morning Onwards, because I can not send message, But now it is working i used daviddavi479's advice.
Thank you David
Hi I can not send SMS message. SMS Message Center Number Error I have a htc touch phone hd . PLEASE HELP
SOURCE: Cant send message...
Tap Start >> Settings >> Phone, go to Services tab, select Voicemail and Text Messages and tap Get Settings. You may change the service center number from here. In case you do not know the correct number, call up your SIM provider and get the number from them.
