Please send me a prior solution
You need to ensure bios is set up with boot up from cd first.Then put your xp cd set up disk in the cd drive and restart pc..From there follow the on screen set up and you will be fine..
FIRST OF ALL YOU CAN INSERT THE WINDOW XP CD IN YOUR CD ROM
AFTER THAT YOU CAN GO THE BIOS SETTING
WHEN YOU START YOUR PC
THEN PRSS F2 OR DEL
THEN
BIOS SETTING APPEARS
AFTER THAT
YOU CAN CHECK THE FIRST BOOT DRIVE
AND CHANGE THE
YOU CAN CHANGE THE FIRST BOOT DRIVE IN THE CD
AFTER THAT F10 AND SAVE THE SETTING
AFTER THAT PRESS ANY KEY TO CD IS APPEAR
THEN PRESS ANY KEY
AFTER THAT SETUP IS START
AND ENTER TO Continue
f8 i agree
and download to c drive
and copy all the file
after that cd key insert
and resart your pc
